Old 01-06-05, 07:56 AM   #1
jonacol
Default Blubs
I don't suppose some kind soul has a list of all the bulbs used on the SV (nekkid '01) so i can put together a little kit for my up coming trip to France?
I tank ewe,
JonC
Old 01-06-05, 08:45 AM   #2
DeeJay
The headlight bulbs are H4....
You can buy bulb kits from Busters accessories.... i think they are all you'll need... can't recall how much they are though... not expensive though...
Old 01-06-05, 12:50 PM   #3
embee
embee's Avatar
you only really need 3 bulbs.
H4 headlamp (P43t type)
Stop/tail
Indicator
Best thing is to whip a tail light and indicator bulb out (takes a minute or 2) to check exactly which type they are and to know that you can do it.
The stop/tails come out from inside the pillion seat, ease out the wires in front of the rear lamp (unhook the tab holding them) and undo the bulb holder a 1/4 turn anti-clockwise.
The indicators have a small phillips/crosshead screw in the underside, then the lens/holder assembly is hooked into the inboard side so ease the outer side outwards from the case and slide the lens outwards away from the bike. It took me several minutes to find out how it came out of the back shell first time.
Indicators are regular equal pin types I'm pretty sure (PY21W or 382 or BA15S), and stop tail are unequal level pin types (P21/5W or 380 or BAY15D), but check for sure because there are different types of staggered/offset pins (equal level is BA15D but not common).
See here
http://www.vehicle-wiring-products.c.../lights-3.html
I've never bothered to carry other bulbs (no.plate and sidelight etc), if you have the main ones you should be fine.
I find they fit nicely on top of the battery cover under the riders seat. You probably won't need them so it's no big deal to have to take the seat off to get to them.
Old 01-06-05, 08:07 PM   #4
jonacol
Thankyou gents, just what i needed.
JonC
