Old 01-06-05, 06:57 PM   #1
shutdown
Default Squeak!
Left work today and suddenly I hear an almighty squeaking noise coming from back wheel area.
It's a real oily (or lack of) squeak and not a brake squeak.
Is there a quick fix for this as I don't think there's going to be time to get it fixed for the rideout on saturday!!
take into this that I know nothing about repairing bikes so taking things apart is probably not going to happen.
I'm concerned about it locking up if its a bearing or something whilst going to/doing the rideout
Old 01-06-05, 07:02 PM   #2
Warren
id suggest wheel bearings . . . cant think of anything round that area that could cause a squeak.
check your brake pads to make sure there isnt a stone caught in there, or a mouse in your exhaust ?
Old 01-06-05, 07:49 PM   #3
shutdown
can i run some engine oil or something around the area to try and lube it or is the bearings area sealed? If it happened last week I could get it into a garage but there isn't time now
Old 01-06-05, 07:53 PM   #4
Warren
i wouldnt say so really.
basically, my theory (it is only a theory mind) is that one of your bearings go, a bearing, is a hollow dounut type thing, with lots of little ball bearings inside packed with grease, these balls move about to make the wheel move round(thats where all the friction goes)
basically, i recon that one of these ball bearings has become crushed or given way under usage, causing a sqeak,
so i recon, if this is the case, it could be a new bearing
no fear, its a very easy job to do yourself.
where exactly is the sqeak coming from ? , and does it occur whenever you turn the wheel round ? or just under the engine.
wait for someone else to come along and suggest some things before you go out and buy the bearings tho, as i could be very wrong indeed.
Car gearbox squeak? the_lone_wolf Idle Banter 24 16-04-09 05:00 PM
paranoid......squeak! jenni SV Talk, Tuning & Tweaking 14 28-08-05 11:01 PM
Odd squeak in the front. sprocket SV Talk, Tuning & Tweaking 3 11-05-05 03:40 PM
squeak shutdown SV Talk, Tuning & Tweaking 9 26-01-05 09:48 PM
