Old 02-06-05, 02:48 PM   #1
U.K.Ajay
Default My horn fell off!
Yep I was happily ridin when me horn fell off! (Please no smut I can't give anyone a good beep at the moment )
Anyway the point is, I now have no clue of the size of bolt I need to refix my horn. I am not the sort of person that has a bucket of bolts in the garage to try it out, so has anyone got a good idea or a clue of the size of bolt I might need.
p.s. probably makes no difference but I have a K2
Old 02-06-05, 02:55 PM   #2
Dan_SV
Oddly enought mine did this too.
Cant recall the size of the bolt off the top of my head, but when I put mine back together I put a little bit of loctite on the thread to stop it happening again.
Old 02-06-05, 02:59 PM   #3
Cloggsy
Default Re: My horn fell off!
Oooof That's gotta hurt
Old 02-06-05, 03:01 PM   #4
embee
embee's Avatar
A classic case of Coitus Interruptus if ever I heard one (parp!)
it's an M8 thread (standard M8x1.25), the length isn't critical providing it doesn't hit the rad, something like 15mm (it might be 12, but up to 20 would probably be OK).
The std bolt has a flanged head, but a flat washer would do the job.
Old 02-06-05, 03:13 PM   #5
U.K.Ajay
Thanks embee, hopefully I will be up and ridin again with a fully functioning horn!
Old 02-06-05, 04:10 PM   #6
Peter Henry
You don't want to be letting that happen too often!(he says half chewed cigar in hand a la Groucho Marx!)
"I never forget a face, but in your case I'll be glad to make an exception."
Old 02-06-05, 05:12 PM   #7
Reckless Rat
I was replacing these with st/st bolts yesterday eve (it was raining )
There's a god-awful double bracket affair with 2 bolts... the bracket 1 to bike was 10mm spanner and the bracket 1 to bracket 2 which the horn mounts on needed 12mm spanner. Both around I guess M5 and M6 (?) x 10mm long.
HTH
RR
i fell for it again tanis34 Idle Banter 22 15-09-08 01:46 PM
fell off... ArtyLady Idle Banter 33 07-02-08 08:58 AM
Fell off. melody Bikes - Talk & Issues 35 06-09-07 08:30 PM
My horn fell off - thumbs up for Mickey Oates Tiger 55 SV Ecosse 4 20-09-06 08:14 AM
9/11 The Man Who Fell Anonymous Idle Banter 25 18-03-06 09:30 PM
