Old 03-06-05, 08:25 AM   #1
thor
Default Clutchless up gear changes are jerky-what should I be doing?
I had a crack at some clutchless up gear changes last night but they seemed very jerky.
From 2nd to 3rd, rising up through the revs, and putting upwards pressure on the lever, gear change happens about 8-9000rpm, but the whole bike lurches. I am keeping the thottle constant. Is that wrong? Should I drop the throttle slightly to compensate, or do the change higher up the revs? It's a K4 if that makes any difference.
Thanks in advance...
Old 03-06-05, 08:31 AM   #2
slippy
Keeping the throttle open is your problem. You should rev up to whatever you feel comfortable with then roll of the throttle and snick up the lever. If you think about it it makes sense as to why your lurching when you keep the throttle open. When driving normally and you have the throttle open you accelerate hence if you have the throttle open when changing gear you will automatically be accelerating hence the lurch when you change gear. Rolling back will prevent this.
Old 03-06-05, 08:37 AM   #3
thor
Ok ta. I'll give that try next time.
Old 03-06-05, 08:56 AM   #4
SVeeedy Gonzales
The throttle roll off doesn't need to be very large and can be done with only a tiny bit of backing off on the throttle - a couple of mm of travel, and light pressure on the gear lever. Sometimes I find it's easier to open the throttle slightly, then roll off as I change gear... but it's all down to personal preference and practice... do whatever works for you and your bike. Personally I find that I only do the clutchless thing if I feel like it, it's not something I want to bother doing all the time.
Old 03-06-05, 09:23 AM   #5
weegaz22
as the others have said, put pressure on the gear change lever and then roll off and on and it wil slot home nicely
Old 03-06-05, 12:37 PM   #6
Captain Nemo
it will change up easier if you wait for the little needle thingy to pass the redline.....
no, seriously , i find that the harder youre accelerating the easier it is to go clutchless. if your not reving hard whats the point?.
Old 03-06-05, 01:25 PM   #7
chazzyb
Keep trying - I did, and after a short while I now find I do it without thinking. I don't usually do 1st to 2nd though, for some reason that escapes me...
Old 03-06-05, 01:30 PM   #8
PoRk ChOp
Practice, practice and practice some more. It is hard to get right, but once you have mastered it, you will find it so much smoother. I do it 90% of the time now, even when just pootling along
Old 03-06-05, 01:51 PM   #9
Scoobs
Exactly!
Jerky Throttle... Biker_Billy SV Talk, Tuning & Tweaking 9 16-07-07 04:36 PM
Clutchless gear changes Larry SV Talk, Tuning & Tweaking 13 12-04-07 02:35 AM
Jerky Throttle Response I'm_a_Newbie SV Talk, Tuning & Tweaking 7 17-10-06 09:47 AM
Clutchless Gear change yvo6 Bikes - Talk & Issues 25 13-03-06 07:22 PM
Clutchless Gear Changes? sweepdoggydog Bikes - Talk & Issues 21 16-08-05 03:14 PM
