Old 04-06-05, 09:14 AM   #1
riktherider
Default sv and svs brakes
is there any advantage of having the plastic master cylinder found on the svs rather than the normal metal master cylinder
Old 04-06-05, 10:21 AM   #2
There's no difference in the master cylinder, the only difference is just the reservoir that holds the fluid.
Old 04-06-05, 10:58 AM   #3
TSM
The Sick Man
TSM's Avatar
thinking a bit to the side, is there a possability that the remote reservoir is more suseptiable to degrading the oil from the sunlight than unfaired one, considering that the unfaired one only has a small glass window while the remote one is all transparent.
Old 04-06-05, 02:19 PM   #4
BURNER
By the time the fluid is brown you should have replaced it anyway, regardless.
brakes / oil lapchick = mad hungarian Ancillaries 4 03-03-07 03:03 PM
Brakes Hogzi Stuff Wanted 0 06-03-06 08:47 PM
Brakes ! stewboy SV Talk, Tuning & Tweaking 3 19-12-05 04:55 PM
Brakes JakeRS SV Talk, Tuning & Tweaking 7 13-04-05 12:15 PM
Brakes - Help! Yokel SV Talk, Tuning & Tweaking 7 11-04-05 08:17 PM
