Old 08-06-05, 04:30 PM   #1
pedrosis
Default Front brake
If your front brake is taking quite a lot of pulling to get on does it need bleeding??
If yes how do you do that then?? (nearly mechanical minded!!)
Old 08-06-05, 04:58 PM   #2
weegaz22
could be a few things, pad material low, needing bled, or theres old crappy fluid in there
Old 08-06-05, 05:01 PM   #3
H-Gerickemark
The best mod I found money can but is to invest in some quality pads, the originals don't seem all that good.
Mark
Old 08-06-05, 11:16 PM   #4
pedrosis
Bled it and now it is better!
Well as good as original SV brakes get
Old 08-06-05, 11:41 PM   #5
BURNER
New fluid, braided lines and EBC HH pads. Good as you'll get, without resorting to serious expenditure.
Old 08-06-05, 11:51 PM   #6
Graham
Most likley the brake lever pivot needs lubing, Remove the lever and clean the bush, Lube and reinstall. Needs doing every year.
The best brake mod out there.
Old 08-06-05, 11:54 PM   #7
pedrosis
I lokked at the EBC HH pads earlier which were about £50 for the front. Is that a good price??
Where & how much for the braded hose?? Are they easy to fit as I am mechanical as a squirrel (with no arms!!)
Old 09-06-05, 07:24 PM   #8
Robw#70
All these upgrades are good but wont really improve much if the calipers are grotty, Sometimes the money is better spent on maintainence, ie make sure the caliper pistons are nice and free, without the dust seals hanging out and the sliders are all in good nick before investing in an upgrade.
These calipers have always been prone to seizing up as the pistons are quite a long way out of the caliper with alot of room for muck to build up
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Front Brake - Rear Brake? Stradders Bikes - Talk & Issues 35 17-09-08 04:44 PM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
