Old 12-06-05, 09:31 PM   #1
MrMessy
Default Wider Rear Wheels:
Does anybody have experiance of fitting a wider section rear wheel to a curvy SV. Preferably one from another model Suzuki.
MrMessy is offline   Reply With Quote
Old 12-06-05, 09:39 PM   #2
ophic
ophic's Avatar
somebody somewhere has. I've seen pics. And someone is bound to ask you why you want to do this.
Silver SV650SK3, Fuel exhaust
Old 12-06-05, 11:24 PM   #3
BURNER
Ben, 21 Quest has fitted a 5.5" from a GSXR1100M to his curvey. Far as I remember he needed new spacers made and a different chain size for the sprockets to match.
Find him in the member list and drop him a PM, he'll give you the details or point you towards the thread where he told us the info.
Old 13-06-05, 07:36 PM   #4
I've not done it myself but there's a spacer kit for a SRAD rear wheel available from SV Race Shop IIRC... Don't know what else is involved though. Though here's something that might help: http://www.svrider.com/tips/gsxr_rearwheel.htm
Old 13-06-05, 08:33 PM   #5
21QUEST
21QUEST's Avatar
Two ways of doing it. Either chage the bearings as in the link Northwind posted or as I did got new spacers made(captive).
Doing it my way you will need two spacers to be made. The cush driver spacer and a spacer for the right hand side. You also have to modify the caliper hanger.
If you are not two far from me I could possibly let you try it out.
Edit : Oh forgot to say you also need a custom sprocket made if you want to use the SV chain size(525) as the GIXER chain is a 530 and you can't get a 525 for it off the shelf
Ben
Nemo me impune lacessit.
Old 13-06-05, 08:36 PM   #6
BURNER
Done!
Next!
Old 13-06-05, 09:41 PM   #7
streetos
I fitted the offside front wheel from a Massey Fergusen MF 300 Series 3 to my curvy. I had to replace the swinging arm with one from a 1933 Rudge Cyclone and do extensive modifications to the exhaust system as well as remove the pillion pegs and put a longer output shaft on the gearbox. It was well worth the effort though as I could then dispense with the side stand.
Old 13-06-05, 09:46 PM   #8
Pah, i fitted the track units from a '44 Tiger tank to my Busa
Old 14-06-05, 12:01 AM   #9
21QUEST
21QUEST's Avatar
What took you so long then
Ben
Old 14-06-05, 12:22 AM   #10
streetos
Finding the 1933 Rudge Cyclone.
wider rear wheel/180 tyre? t18con. SV Talk, Tuning & Tweaking 20 17-06-09 01:10 PM
VFR400 rear wheels rowdy Bikes - Talk & Issues 5 20-09-08 01:40 PM
4 wheels good, 2 wheels better Dysparunia Bikes - Talk & Issues 6 30-11-06 07:37 AM
Wheels GSXR Carlos SV Talk, Tuning & Tweaking 4 19-01-06 02:00 PM
What rear wheels northwind SV Talk, Tuning & Tweaking 4 02-12-04 11:08 PM
