Can anybody explain why I keep squaring off my rear tyre,run at 36p.s.i.
B.T.14 more than 60% of my riding is on lanes[no chicken strips] but I still have managed to square off my third set of tyres in 10,000 miles The tyres aren't worn out just a flat middle Suspension setting?? [On notch 5 for 95-100Kgs with my gear on] More tyre pressure??? Less hard acceleration?? What????????????????? Starting to get expensive 3,300 MILES PER SET |
Possible contributary factors:
Pressures you run. Bit happy with the loud handle. Heavy footed on the rear brake. Using stickys, no way round that - sticky tyres = short life whatever you do. Worn shock - suspension has a pronounced effect on tyres. Bumpy/rippled roads - wheel spin's not necessarily perceptible but shags tyres. HTH
accelerate less on the straights and more coming out of corners?
#4 | |
Malc
Sorry mate, I never meant it really ![]()
Hahaahahahahahahahahahahahahah
Your complaining because you got 3000 miles out of a rear 014. That was good wear for me! I changed to Avons because the last rear 014 on mine did approx 1100 miles............My old man gets more mileage out of them on his blade for fecks sake! (and he doesn't hang about, in fact makes me look like I'm hanging about) I'm afraid thats the way it goes mate. It was suggested to me (by a tyre advisor from one of the leading tyre wholesalers) that possibly the low (36psi) pressure I was running the rear at was contributing. It was also suggested that the way a twin delivers its power pulses could be contributary. Bridgestones reccomendation is 36 front 42 rear. Hope that may help you. Dan |
Thanks everybody,I'll try the 42psi. setting on the next set and see if it makes any difference over a prolonged period. I did try it before but I thought it made the tail a bit "SKIPPY" so I dropped back to my 36psi.
Cheers Mac |
#8 | |
#9 | ||
#10 |
I have just tried to prove a point to myself today. I raised my pressures to those that have been mentioned on this and many posts.
At 42 / 36 the bike just doesnt feel right, it is skitty and feels like I am on marbles ![]() ![]() |
rear tyre squaring off? | hcorf | SV Talk, Tuning & Tweaking | 18 | 25-07-06 06:57 AM |
