Old 16-06-05, 06:20 PM   #1
tee jey
Default Raising forks thro' yokes
Has anyone had experience of raising the forks through the yokes by a few mm to speed up the turn in to corners?
If so, by how much of the forks did you have above the top yoke?
Did you suffer any instability at high speed as a result? Is it worth doing?
The suspension on my 03 SVS is standard at the rear but the front has Progressive spring, 10 W fork oil and 26mm static sag.
Old 16-06-05, 06:49 PM   #2
BURNER
I'd lift the back before altering the front, which I have on my mark I.
Turns quicker with just enough twitch to keep it interesting, weaves at 130 but how often do you ride that fast?
Old 16-06-05, 10:05 PM   #3
tee jey
I am trying to avoid this route as it requires buying new dog bone, some spannering and some means of supporting the rear end.
Changing the front end seems and easier option - perhaps.
Old 17-06-05, 09:34 PM   #4
Robw#70
Cheaper option until something digs in the deck and cartwheels down the road
Old 17-06-05, 10:10 PM   #5
fizzwheel
fizzwheel's Avatar
Mines been done, about 10mm I think, I dont know what its like as standard as the previous owner did this and I left it like it was rather than put it back to standard
My Brother has done this to his NC35 and he said it helped with the turn in a lot
Old 19-06-05, 11:29 PM   #6
I had mine dropped by about 14mm eventually with the seat up around 35mm. Some would call it unrideable But I liked it. It made holding a clean line more difficult as the bike was very eager to change direction, but on the other hand it meant that even if things started to go a bit wrong in a bend it was relatively easy to make adjustements.
I've had to drop the seat until my leg heals up a bit more, it's only about 10mm up now... Strangely that didn't work well with the 12mm drop, after more experimentation I raised them back to 5mm down, which slows things down but makes for less erratic cornering.
Rob makes a good point but how many of us are going to be dragging pegs on the road? AFAIC that's just bad riding.
Old 20-06-05, 09:39 AM   #7
Stef
I dropped my forks 20mm and I've installed hyperpro springs and 15wt oil. These mods elevated my corner speed quite a lot, but this is mostly because of the springs and oil. I do like the crispier turn in a lot. If you like a nimble bike, do it.
Old 20-06-05, 10:26 AM   #8
Captain Nemo
20mm !!!!!!! youre brave, ive dropped mine about 8mm with new springs and oil and it makes a big diff, almost finished making my dogbones to lift the back, then listen to my missus complain, she will need oxygen up there.....
Old 20-06-05, 10:46 AM   #9
Stef
Well, considering my weekend/trackday bike is an Aprilia RS250, I guess I'm used to nearly vertical forks
Old 20-06-05, 10:52 AM   #10
Cloggsy
Geez' that's low
Pointy forks and yokes etc Lozzo Stuff Wanted 5 22-01-09 07:23 PM
Dropping the yokes down the forks? Berlin SV Talk, Tuning & Tweaking 4 20-09-07 10:55 AM
usd forks and gsxr750 yokes riktherider SV Talk, Tuning & Tweaking 4 21-07-07 07:45 PM
dropping forks through the yokes. Warren SV Talk, Tuning & Tweaking 8 25-09-06 09:16 PM
Raising forks through yokes? Dougweb SV Talk, Tuning & Tweaking 5 30-08-06 08:16 AM
