Old 18-06-05, 01:59 PM   #1
pedrosis
Default Life of rear brake pads
Hello
I have just got a new back tyre fitted and they said my brake pads needed doing too.
I have done about 10,000 miles. is that a bit carp? Was hoping they would last a lot longer than that as I hardly use the back brake
Also I paid £220 for a new metzler tyre and the pads plus labour. have I just been ripped off too???
Thanks in advance for any replies
Old 18-06-05, 02:02 PM   #2
Carsick
Which Metz was it?
New rear pads are less than £20 and shouldn't take longer than 30 minutes to fit (they actually take about 10 minutes, but I'm lazy)
Mine were just reaching the end of their life at 15k, so yours were probably well on the way but I doubt they actually needed replacing.
Old 18-06-05, 02:06 PM   #3
pedrosis
Its a roadteck Z6
Also they used a ton of lube on bits of my bike which BRIDGE in exeter FAILED TO DO!!!!
Only slightly annoyed that my rear wheel was about to sieze up!
GRRRRR!!!
Old 18-06-05, 02:54 PM   #4
Clunk
Mine's done almost 13,000 on original pads front and back.
Not down to the wear limit yet, but getting close.
Old 18-06-05, 03:10 PM   #5
pedrosis
Hmmm
Me thinks I could have been ripped off just a bit then
Oh well new can in september will make me happy again
Old 18-06-05, 04:23 PM   #6
jonboy
I've gone through four sets of rear pads in 26k miles and am still on the original fronts, so really it's a question of how you brake that determines what will wear and how often.
However, if you don't use much rear brake then it could well be that they're binding which could account for the wear.
Old 18-06-05, 06:01 PM   #7
wheelnut
My rear pads were replaced at 9000, for £23 but I think they were binding a little, as I hardly use the rear except in town.
My front pads are still looking ok at 13000 and i tend to ride quite hard and use the front brake in the same casual manner
Old 18-06-05, 10:25 PM   #8
Warren
i got 16k out of my rear pads, just had my fronts replaced at 24k,
i ride through towns mostly - to i use alot of rear brake.
i both BT010 and a BT020 fitted for 180 quid if that helps
Old 20-06-05, 10:33 PM   #9
OF.uk
27,000 miles out of rear pads and not ready for replacing yet (still original from new), only on 2nd set of fronts
Rear Brake Pads svdemon SV Ecosse 13 24-03-09 08:47 PM
Rear brake pads---Curvy 21QUEST For Sale - SV's and SV related items 4 08-04-08 09:09 PM
rear brake pads kcowgergmm SV Talk, Tuning & Tweaking 4 31-07-07 10:59 AM
Rear Brake Pad Life Sholay SV Talk, Tuning & Tweaking 20 09-08-05 12:56 PM
Rear brake pads creamerybutter SV Talk, Tuning & Tweaking 8 15-07-05 12:54 PM
