Old 22-06-05, 04:21 PM   #1
Marius
Default fram oil filter code?
as many of you know me well on these days...
have one more question:
i put aral semi synthetic oil with the correct spec. the oil was realy clear, when i put it in. now the oil is not so clear, as i can see it through the glass window. my bike is 2003 october make, and i put fram oil filter, with the code ph6018...maybe the filter is not right?
but i checkit over the net, and nowhere you can get a code for sv after 2003 make?
help
Old 22-06-05, 06:17 PM   #2
The oil darkening is completely normal, nothing to worry about.
The same oil filter is used for both the early and late model SV650, and loads of other Suzukis too.
Old 22-06-05, 07:19 PM   #3
TSM
The Sick Man
TSM's Avatar
I beleave its an 138, HF138, KN138 etc...
Usaly manuf code e.g KN (K&N Filters) then 138 which is the filter type and usaly the same with most manufs.
These are all the bikes that use the same filter
http://www.knfilters.com/search/appl...px?Prod=KN-138
These are other part numbers that the filter can be (only suzuki listed)
http://www.knfilters.com/search/kn_c...aspx?kn=KN-138
Old 22-06-05, 08:47 PM   #4
Marius
thanx lads, i was worrrrying that oil filter till 2003 is different from the oil filter after 2003,. cos suzi added thei oil cooling system...
thanx for help and cheering me up...
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
dress code timwilky Idle Banter 25 08-04-06 10:15 AM
colour code mouldy Bikes - Talk & Issues 1 12-03-06 06:32 PM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
