Old 24-06-05, 08:42 AM   #1
dogmartin
Default idle ideas
Hi there,
Jumped on the ol' 650 this morning ('99 model). it started fine as usual but just wont idle. Stalls unless I keep the revs up. Any ideas?
Old 24-06-05, 08:47 AM   #2
BillyC
BillyC's Avatar
Yeah... try adjusting your idle speed screw!
You need to be aiming for between 1300 and 1400 RPM
Welcome to the site by the way
Old 24-06-05, 08:49 AM   #3
dogmartin
will do
Old 24-06-05, 11:45 AM   #4
Brand New
Hi guys, I have the same problem, idle speed is around 1000 and it stalls if not warm.
Main part of the question would be, where is the idle control screw??
Cheers,
BN
Old 24-06-05, 12:16 PM   #5
svpilot
Its on the LHS of the bike between the frame, its a small black knob you can turn by hand. HTH
Old 24-06-05, 12:26 PM   #6
dogmartin
Got a chance to get out into the garage and the bike is running on 1 cylinder. So going to check the plugs.
Old 24-06-05, 12:42 PM   #7
NitroNorry
Default Ditto
Mine used to stall as well with an idle around 1100. I changed it to 1400 and it is fine now.
rgds
Martin
Old 24-06-05, 12:55 PM   #8
dogmartin
Yes! Sorted. New plug and I'm done. Just in time for the thunder and lightning!
Idle again! Jamie_SV SV Talk, Tuning & Tweaking 2 08-03-08 03:30 PM
idle revs...... keithd SV Talk, Tuning & Tweaking 3 13-07-05 11:17 AM
IL4 Idle... DeeJay Bikes - Talk & Issues 26 26-05-05 03:11 PM
