Old 24-06-05, 08:17 PM   #1
hutchy
Default bugs with grit
I've had my SV 2 days and I've covered 250 miles, covered the front in bugs - so when I got home I got the tissue out and a bowl of luke warm water and set about cleaning them off,
It was only when I'd finished and dried off that i noticed small scratches on 1 side of the front fairing! doh! nowhere else (I'd been really carefull to soak the bugs then wipe them off)
My question - can i use t-cut on the fairing with it being plastic or will it make things worse?
Old 24-06-05, 08:28 PM   #2
fizzwheel
fizzwheel's Avatar
I wouldnt use it on brand new paint work no, but then I dont know what else to suggest.
Hopefully somebody can advise you though
Old 24-06-05, 08:29 PM   #3
Carsick
I agree with fizz, don't use the abrasive one till you've had several layers of wax on there.
The colour match type polish should be alright, but I don't know how well it'll cover the scratches.
The front of my bike is absolutely covered with those little marks (as well as quite a few dead bodies)
Old 24-06-05, 08:32 PM   #4
jaysv650
dont use it on new paintwork. its too soft
Old 24-06-05, 11:14 PM   #5
embee
embee's Avatar
the various products like Autoglym Motorcycle Cleaner work really well to remove flies and hot weather type crud from the bodywork, and clean wheels a treat.
I use it sparingly and only when really necessary.
Otherwise use a good bodywork shampoo for washing it (Autoglym, Mer, Meguiars etc). Once it's really clean, use a normal polish (again the usual makes, I prefer Autoglym), and it'll ease out any very slight scratches. Don't use T-cut or similar, way too abrasive.
Old 25-06-05, 12:03 AM   #6
RandyO
bug guts are more corrosive than winter salt
Old 25-06-05, 03:01 AM   #7
TC3
Default Re: bugs with grit
Thats one reason i did not get a black one as the marks will be more obvious
Old 25-06-05, 03:11 AM   #8
adam
Try leaving a fairly damp tea towl over the fairing for 5-10 mins first , it really helps loosen the crap, most will just wash off with a hose then.
Similar to soaking that bowl with yesterdays wheatabix in.....
Sorry I didn't answer your question lol - No idea about using T-cut, I certainly wouldn't use it often or as a solution to removing scratches.
True grit hare+hounds 1st feb BILLY Photos 18 08-02-09 10:09 PM
True grit hare+hounds 1st feb BILLY Pennine Massive 12 02-02-09 08:18 PM
True grit hare+hounds 1st feb BILLY Idle Banter 3 29-01-09 09:57 PM
Want to see something possibly interesting? WARNING: don't enter if you don't like bugs.... :P missyburd Photos 58 13-12-08 01:16 PM
bugs! kwak zzr Bikes - Talk & Issues 30 08-07-06 06:15 PM
