Old 03-07-05, 06:14 PM   #1
NAPA121
NAPA121's Avatar
Default Install Scottoiler on SV650
I want to install a Scottoiler on a 2004 SV650. I know you have to connect to the vacuum, is this easy to get to and is there anything special I need to know? Any other advice on installing the Scottoiler would be appreciated.
Thanks
Neil
Ex Owner of a lovely Naked Blue K4 SV650
Ex Owner of a Buell Lightning Long XB12Ss
Proud Owner of a Yamaha FZ1-N....Man this thing is quick
NAPA121 is offline   Reply With Quote
Old 03-07-05, 07:35 PM   #2
Mr Toad
The vacuum pipe is very easy to get to - it's capped by a small black cap on the front of one of the cylinders - remove that & pop the tube on
Have a look at the Scottoiler website as it's got lots of info about installing
Old 04-07-05, 03:05 PM   #3
tomjones2
when u fit the delivery pipe on the swinarm check that u have left enough clearance for the swinarms full suspension movement (including having the rear wheel off the ground)
really easy job though
Scottoiler Install 05 SV650S tayto94 SV Talk, Tuning & Tweaking 28 29-12-08 06:47 PM
scottoiler install krazdndenver SV Talk, Tuning & Tweaking 1 15-03-08 11:11 PM
How to install driver Stu Idle Banter 2 25-07-07 12:22 AM
636 shock install TSM SV Talk, Tuning & Tweaking 5 20-07-05 10:35 PM
Help with exhaust install ahlb0018 SV Talk, Tuning & Tweaking 8 21-02-05 12:43 PM
