Old 03-07-05, 10:41 PM   #1
rob13
Default Chain Wax
At the moment im using Wurth High Performance chain oil on the chain however it doesnt seem to stop it from getting rusty so to complement it i was thinking of buying some Chain Wax to protect it from the elements. I love the fact that the Wurth HP Chain Oil doesnt flick up at all onto the wheel.
Which is the best wax to buy? Is wax the way forward to prevent rust?
Old 03-07-05, 10:57 PM   #2
wheelnut
I was experimenting today as my chain was looking a bit uncared for.
I used some old engine oil and a brush and worked it into the chain, then sprayed it with wax to seal it.
Not sure if it worked but the chain is shiny on the rollers and the swingarm and wheel is still clean.
Im not sure if there is a better wax than others, but Wurth is good, and expensive unless you get it for free :P
Old 04-07-05, 12:15 AM   #3
BURNER
I clean mine with WD40 and then use Castrol chain wax. I also have a scottoiler but the bike sits for a whole week, outside, without use sometimes.
Old 04-07-05, 05:27 PM   #4
svpilot
Default Re: Chain Wax
I had the Wuth chain wax, and my chain used to go rusty at a hint of rain.
I run a loobman now. Chain is nicely lubed ...
so is back wheel and garage floor
Old 04-07-05, 05:43 PM   #5
Warren
thats the best way to do it so i hear.
the above information does not pass BASAT
Old 04-07-05, 06:46 PM   #6
i use pj1 it seems to keep the chain in tip top order but it aint a wax.
Old 05-07-05, 08:36 AM   #7
BillyC
BillyC's Avatar
Wax is all very well, but don't you have to clean your chain regularly, otherwise the wax gathers dirt and grit, and starts grinding into your chain and sprocks?
Just get a Scotty
Old 05-07-05, 08:40 AM   #8
Jabba
Originally Posted by BillyC
Just get a Scotty
Agreed.
Old 05-07-05, 08:46 AM   #9
BillyC
BillyC's Avatar
Just get a Scotty
Agreed.
We agreed on something?
Old 05-07-05, 09:03 AM   #10
brolong22
I have used Holts 'motorcycle' chain lube from halfords wich was a waste of money, looks like snot and flies everywhere with even the most sparing application despite 'non fling' formula.
I used a can of castrol chain wax recomended by my dealer wich was fine
and now im using a can of putoline wax cos thats what they sell at my nearest shop and so far its been the best stuff.
Chain Always Loose, New Chain? RGSPro SV Talk, Tuning & Tweaking 8 02-07-10 10:05 AM
Cam Chain jambo Stuff Wanted 6 05-08-08 10:28 AM
Chain on the way out? krhall SV Talk, Tuning & Tweaking 5 20-04-08 07:14 PM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
