Old 06-07-05, 04:05 PM   #1
tillerthou
Default kmh to mph clock swap
the title says it!
can i plug in mph clocks into an import sv650s (2000 model) an expect them to work ok?
thanks
Old 06-07-05, 04:12 PM   #2
BillyC
BillyC's Avatar
I don't see why not....
.... or you could just get a K3 or later
Old 06-07-05, 04:14 PM   #3
BoltonSte
Works fine, the sender is the same, (same pulses/intervals) the chip in the clocks converts it to kph/mph thats all. I did a straight swap with mine and had no issues.
ste
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 06-07-05, 05:31 PM   #4
tillerthou
svste, thans very much!!!
Old 06-07-05, 08:30 PM   #5
Stig
I'm sure somewhere on the web is a place that can convert your clocks to mph. Will see if I can find it.
Old 06-07-05, 08:32 PM   #6
Stig
Here it is
Old 07-07-05, 10:51 AM   #7
BoltonSte
I used to have a little black box on mine which messed with the pulses so that the clock was still kph but showed mph speeds. Only problem I had with it was that the kph only had every 20kph on. IIRC, hence why I changed, I think I still have some paperwork around, deffo cheaper than a new set of clocks.
ste
Had an SV or three.
Old 07-07-05, 07:37 PM   #8
tillerthou
i wanted the new clocks so they read upto 150mph and not look like it goes to 240mph!! it already has a convertor on it - but only half the speedo is ever used with this method!
also, i want miles odometer - if i just put a new face on it and remove the convertor, the odo would still be in km.
thanks for the link!
clock swap mph to kph noob-saibot SV Talk, Tuning & Tweaking 7 02-02-09 02:56 PM
pointy clock cover(thingy on the back of the clock)!!!! ben650 Stuff Wanted 0 09-04-06 12:47 PM
Clock on K3 lukemillar SV Talk, Tuning & Tweaking 3 08-02-06 08:06 PM
Can somebody set the clock timwilky Idle Banter 9 30-01-06 10:40 AM
oh to swap or not to swap that is the question.. DrPain Bikes - Talk & Issues 27 25-04-05 02:48 PM
