Old 06-07-05, 06:43 PM   #1
madmartyn
Default help
right got led brake lights on me curvy they been working fine and lovely till this morning now i can either have no lights on and brake lights work or turn on side lights and brake lights are on checked wiring still looks the same as when i put them on nothing obvious, indicators still work either with lights on or off( the rear ones are part of the same cluster type thing) so i,m stuck anyone any ideas
Old 06-07-05, 08:03 PM   #2
OF.uk
I have one but will have to check with Big Ape first to see if it's ok to post
only joking. Hope you get it sorted soon.
Old 07-07-05, 07:39 AM   #3
Sounds like one of the earth, (neutral), connectors, isn't. The unit will still work as the various lights will earth in series with another, causing the problems you describe. If the unit has more than one earth make sure they're all connected properly, if it only has one then it's possible that an internal connection has failed.
I'd remove all the wires, identify and connect the earths, then connect each live feed in turn to a 12V supply, (the battery), with a flylead as this will obviate any other imperfect connections, if it all works right with the other wires disconnected then a failed connection on the bike is most likely.
Old 07-07-05, 05:56 PM   #4
John Burt
Have you made sure the bulbs are fitted correctly, if their 180 degrees out this kind of thing can happen.
Old 07-07-05, 05:57 PM   #5
didge
I have one but will have to check with Big Ape first to see if it's ok to post Wink Laughing
lol
Old 07-07-05, 06:30 PM   #6
Stig
lol
I really think this is getting out of hand now
Old 07-07-05, 07:59 PM   #7
madmartyn
finaly tracked it down to a dodgy bulb holder thanks
