How do you find the tight spot on the chain?
Is this a wind up?
Anyhoo, get the back wheel off of the ground and rotate the wheel. The tightspot is where the chain is the least slack. |
With the rear wheel off the ground, check the tension of the chain on the lower run midway between the sprockets. Turn the wheel a bit, so the chain moves 4" or so, and check again. The place where it has least up and down movement is the place you need to check when adjusting the chain.
#4 | |
Not all of us have very much knowledge regarding bikes. I had it up on the paddock stand on sat evening and tried finding the tight spot. There were two places where the chain felt slightly "sticky" between the sprockets but I wasn.t too sure if that was the tight spot or not ![]() |
#5 | ||
With a chain you can have sticky links or a tight spot. Sticky links are where the movement between the links is tight. A tight spot in the chain is where you have less slack. This is because either the chain is worn in certain places or the sprockets are slightly oval. Does this make sense? It does to me as I type it, but I know what I am trying to say. |
Good luck mate.
Just as a side note, In case you were not aware. When adjusting the chain, make sure that as has been said that you adjust it at the tight spot, and also making sure that you have the correct tension for the chain at this point. Adjusting the chain at the correct tension on any other part of the chain will cause severe stress on the chain, wheel bearings and the gear linkage arm, possibly causing more damage.
#9 |
Just a thought, is the tight spot always the same place? if so you could mark it with a spot of paint?
#10 | |
If both sprockets were the same size, then in theory yes, but in this case no. |
finding a job after uni | riktherider | Idle Banter | 6 | 07-07-08 08:32 PM |
Rear Axle bolt -how tight is tight | MavUK | SV Talk, Tuning & Tweaking | 4 | 02-03-08 11:47 PM |
tight screw | hovis | Bikes - Talk & Issues | 13 | 04-01-07 01:45 PM |
Helmet too tight? | PsychoCannon | Idle Banter | 3 | 22-09-06 02:39 PM |
tight nipple | madmal | SV Talk, Tuning & Tweaking | 18 | 01-02-06 07:20 PM |
