Old 12-07-05, 09:14 AM   #1
alkap
Default Scottoiler installation during bike warranty period
Greets,
I was planning to install Scottoiler universial kit to K5 that i got recently. But the bike is still under warranty. Does it mean that the bike warranty would be cancelled then? Does Suzuki has worldwide warranty or is it contry specific?
I could let dealer to install the Scottoiler kit, but he kind a disagrees such kind a things. Saying that whole bike will be messi and covered with oil because of that. And it would be way more efficient to wash with brush and oil the chain after each 500km. And after that i might want to have an automatic wheel changer. So i don't think he would be happy to install it for me.
Needless to say that i am lazy anough not to wash the chain after every 500km and really i have even no idea how to do it.
(think need to buy a bike stand with what i could raise the rear wheel... )
Regards
alkap
Old 12-07-05, 10:27 AM   #2
BillyC
BillyC's Avatar
Your dealer talks crap.
The Scotty will more than likely double the life of your chain and sprockets, and reduce the general maintenance that it requires.
Your dealer probably just doesn't want to lose this lucrative part of his business, in supplying, and fitting, chains and sprockets.
Old 12-07-05, 11:40 AM   #3
tomjones2
agreed i cant speak highly enough about scotoiler products and there customer service
Old 12-07-05, 11:45 AM   #4
Cronos
Your dealer is so full of it that his eyes are turning brown.
Suggest you install scottoiler and give your business to another dealer.
Old 12-07-05, 11:56 AM   #5
fizzwheel
fizzwheel's Avatar
Agree with the others, Scotoilers are the best thing since sliced, bread.
It cover your bike with oil unless you set the drip rate to high
Old 12-07-05, 12:48 PM   #6
SV650Racer
It wont affect your warranty.
Old 12-07-05, 01:49 PM   #7
Red ones
Red ones's Avatar
Does it alter the performance of the bike? Does is increase wear on non-consumable parts? No.
Won't affect the warranty (or if anyone argues that it does, you have grounds to agrue the case)
Does it make a mess of the back wheel - only if you set it wrongly.
Do they do a good job - Yes. I do about 1500 miles a month and cant be bothered to do the chain every 2 weeks - a real saver for me!
Old 12-07-05, 02:16 PM   #8
SV650Racer
The only way i could see them rejecting a warranty claim is if the scottoiler damages a part or causes a running fault on the bike which is very very unlikely.
Old 12-07-05, 05:41 PM   #9
Stig
Even if you use a chain lubricator other than a scottoiler, your chain is going to produce "fling" on the rear wheel. I also would be lubricating the chain more frequently than every 500km.
If you use scottoil in the oiler the fling that is produced on the rear wheel is a damn site easier to clean off than chain wax or oil.
The other considerable benefit of using a scottoiler over chain lube or wax is it makes the chain virtually maintenance free, no cleaning required. Chain adjustment is less frequent. And as has been said, can double the life of your sprockets and chain, if not longer.
Old 12-07-05, 07:08 PM   #10
jonboy
I examined my chain very thoroughly tonight and after 7k it's rather knackered with unreasonable play in quite a few links with several serious tightspots. It also has approx 20% of the X-rings missing .
Now I put on an Iris Gold 0-ring and Talon sprockets (rear is a 46 tooth alloy). The front sprocket is slightly hooked and the rear just slightly worn. Have I ever cleaned it? Many many times. Have I lubed it? Almost excessively and usually every 50-100 miles.
Did I put my Loobman oiler on? No . Will do next time.
It's the third chain I've had in 27k, the Suzuki one lasted 16k, then an SSS o-ring lasted 4k (but stupidly kept the original sprockets) and now this chain and sprockets need replacing very shortly though might be able to hang it out for another 1000-1500 miles or so.
And people wonder why I hanker after shaft drive .
Anyway the point of this post is that a chain oiler is a damn fine idea whether it gives excessive fling or not.
Will a Scottoiler fit any bike? rob13 Bikes - Talk & Issues 13 11-11-08 11:04 PM
Notice period Viney Idle Banter 6 29-07-08 07:51 AM
driving licence after 2 year restrcition period riktherider Bikes - Talk & Issues 12 09-06-07 09:43 AM
GSXR Cutting out after a period of high rev's problem mysteryjimbo Bikes - Talk & Issues 7 22-07-05 03:46 PM
Warm up period - How Long???? branny SV Talk, Tuning & Tweaking 2 17-05-05 12:21 PM
