Old 14-07-05, 12:35 AM   #1
rcmark
Default Carb sync - Fuel injection
I know about syncing the carbs. Is their a simular process on fuel injected 'computer' SV650's?
Old 14-07-05, 07:00 AM   #2
Scoobs
Default Re: Carb sync - Fuel injection
I believe so, although I have never done FI. I understand that you have to sync the throttle bodies similar to the way you sync carbs (which I have done).
Old 14-07-05, 07:11 AM   #3
Process is identical; connect vacuum gauges in the same manner*, twiddle balance screw similarly.
Set the TPS while you're there.
*Easier with FI, no vacuum hoses to disconnect/tee into.
Old 14-07-05, 07:26 AM   #4
Scoobs
Well done Sid. Now I know too.
Interesting carb sync tool pilot SV Talk, Tuning & Tweaking 7 04-04-08 05:47 PM
CA Model Carb Sync ? rcmark Bikes - Talk & Issues 1 16-08-05 09:27 PM
Carb sync tools TSM SV Talk, Tuning & Tweaking 0 19-07-05 09:20 AM
Carb Sync: £11.99 and works! snoopy SV Talk, Tuning & Tweaking 33 31-05-05 10:11 PM
Fuel Injection... steveo SV Talk, Tuning & Tweaking 6 23-11-04 01:43 PM
