Old 22-07-05, 10:22 PM   #1
bingnet
Default My sv650 is GUTLESS!
Howdee all, I just xported my '00 sv650 to new home in Portland, OR. I came from Guam (Pacific island). I had drained fuel and oil for the xport. After replacing oil and a new gas tank (due to rust) the bike has NO TORQUE. It takes a few seconds to red line with full throttle in NEUTRAL! I have little mechanical experience and don't know a good shop around here, yet. What are some things I can read about or check to troubleshoot this problem?
Thank you!
Ken
Old 23-07-05, 12:09 AM   #2
BURNER
Strip and clean the carbs first.
Old 23-07-05, 01:14 AM   #3
bingnet
Is that something I can do with the carbs still on the bike? I have some chemtool carb spray cleaner. Where do I spray it? I removed the airbox and drained the float bowls. The rear bowl was full, but the front bowl did not drain but a couple of drops. Is that normal?
Old 23-07-05, 03:59 AM   #4
bingnet
Default Aha, now what.
After further testing...
It seems the problem is this: the front cylinder is not getting gas. When I drained the float bowls the front bowl did not have any gas in it. When I sprayed carb cleaner into the front carb the engine ran normally until it consumbed the carb cleaner. I detached the fuel line from the front cylinder and tried blowing into the carb with the float bowl drain valve open. I was unable to force any air through the carb. Looks like a blockage in the carb. Know a good place online for a carb rebuild kit?
Old 23-07-05, 11:40 AM   #5
BURNER
Take the carbs off the bike, strip and clean them. It's easy, if you've got a digi cam take pics of each stage. Take the bowl off, remove the main jet and clean the lot.
Get a workshop manual or a UK Haynes manual.
Old 23-07-05, 11:56 PM   #6
Raf
The service manuals are here http://www.sv650.org/sv_manuals.htm
Old 24-07-05, 02:27 AM   #7
BURNER
Good call that man. Never knew the manuals were uploaded here honestly.
Exactly right tho, btter to refer someone to the actual manual. I'm no technical marvel, so I couldn't write a manual. Any advice I gave may be entirely factual and therefore spoken from the darkest corner of my bowel.
sTeLLA rOX
Trading sv650 for sv650 sport?? Wycombe Dave Bikes - Talk & Issues 12 24-08-08 10:26 PM
gutless Wideboy SV Talk, Tuning & Tweaking 14 07-01-08 07:18 PM
G-PACK for SV650 SV650S SV 650 SV650 S - EFI MODELS - Timing Retard Eliminator ThEGr33k SV Talk, Tuning & Tweaking 0 25-11-07 12:22 AM
will a 2002 sv650 s cylinder head fit my 99 sv650? bugsy46 Bikes - Talk & Issues 2 07-04-07 04:26 PM
Will the forks off of a 03-05 SV650 fit a 99-02 SV650? Clarker SV Talk, Tuning & Tweaking 3 24-05-05 09:30 PM
