Old 26-07-05, 11:57 AM   #1
muddycoffee
Default Burning smell from radiator after a ride in heavy rain
I got caught out in the rain on sunday and had to ride back about 40 miles while getting we through.
When I got home I smelled a burning rubber smell coming from the radiator area. NExt time I rode the bike to work I noticed the smell coming back when the engine was warm.
I checked the radiator coolant and there seems to be full to the top and no evidence of any leaks.
Also there appears to be a little water dripping out of the little drain pipe which comes out under the back brake lever.
Is this anything serious,
has it happened to anybody else?
should I be worried?
help...
Old 26-07-05, 12:37 PM   #2
muddycoffee
It has just occured to me that the fan might be faulty, as the only time I heard it on was when I went for a long ride in the heat a few weeks ago. Should the fan come on all the time or only when riding hard or in hot weather?
Old 26-07-05, 12:46 PM   #3
Amanda M
The fan will only come when when it's really hot.
Old 26-07-05, 12:48 PM   #4
Grinch
It should only really come on when its hot.. or long rides.. if the weather is wet and cold then there maybe no need for it. Did the temp light come on? If not then it probably hasn't over heated.
Old 26-07-05, 12:50 PM   #5
Grinch
Default Re: Burning smell from radiator after a ride in heavy rain
help...
The smell might be something rubber of plastic thats got on you pipe or engine and heated up.. check to see if something has got caught up in the bike.. Then mines always 'smelt' warm after a long ride, are you sure its not that?
Old 26-07-05, 12:54 PM   #6
muddycoffee
..might be something rubber of plastic thats got on you pipe or engine and heated up.. check to see if something has got caught up in the bike.. Then mines always 'smelt' warm after a long ride, are you sure its not that?
It smells like something rubber, rather than a hot bike engine, I think you might be right about something stuck, I'll have a look this afternoon.
thanks
Old 26-07-05, 01:12 PM   #7
Liam
Reminds me of the time I pushed the hot bike past a garden refuse bag when putting the bike away - spend 20 mins on next fire up worrying what the smell & smoke was. Hell of a mess to clean up too
Liam
Old 26-07-05, 02:30 PM   #8
muddycoffee
Thanks guys, smell is now gone and everything is back to normal as far as I can tell. I assume I caught a bit of rubber or plastic somewhere hot and it has fell or burned off now..
Old 26-07-05, 02:33 PM   #9
Grinch
Thanks guys, smell is now gone and everything is back to normal as far as I can tell. I assume I cought a bit of rubber or plastic somewhere hot and it has fell or burned off now..
Glad to hear...
Old 26-07-05, 02:35 PM   #10
wheelnut
If it makes you feel any better, my bike smelt awful coming back from donington in the rain, I wondered if the water had got in the fan electrics, but no it was running ok
There was more steam coming up behind the screen than Fred Dibnah's traction engine.
I once melted a pair of Doc Marten boots on my mates bonnevile exhaust, it took months to remove and it stunk awful too
Burning Smell crzylanesplit SV Talk, Tuning & Tweaking 23 05-02-09 12:34 PM
Burning smell - advice please. Vespillo SV Talk, Tuning & Tweaking 15 29-12-08 09:00 PM
Burning smell Baz SV Talk, Tuning & Tweaking 10 04-07-08 09:01 PM
burning smell steveg SV Talk, Tuning & Tweaking 18 31-01-08 06:13 PM
Engine Burning Smell MarkyBoy SV Talk, Tuning & Tweaking 7 26-09-06 02:25 PM
