Old 02-08-05, 07:20 PM   #1
Cloggsy
Default What headlight bulbs does a curvy take?
Do they take H4's like the pointy or not
Old 02-08-05, 07:37 PM   #2
markf
Default Bulbs
H4's like the pointy's
Old 02-08-05, 08:01 PM   #3
The standard bulbs are 45/45w H4, although most people have used 60/55w with no troubles, as with all plastic lensed headlights it's best to avoid unbranded bulbs as some are not adequately UV shielded which can cause damage to the headlamp lens, it's that not extra heat which is the usual culprit.
Old 02-08-05, 09:46 PM   #4
why cloggsy ru gettin an SV-
had enuff of that cheap off roader????
serious though- why?
does someone you know need some-
I have uprated mine to Philips blue and have 2 spare original ones ..if its helpful
Old 02-08-05, 09:51 PM   #5
now i understand-
from yer selling post ....!!!!
u were just clarifying??
Old 02-08-05, 09:52 PM   #6
Spanner Man
Evening.
As the Squid says, avoid non branded bulbs as they can cause your headlamp lenses to go cloudy due to inadequate UV shielding...
If it's better light you're after you can get 60/55 H4 bulbs that are anywhere between 30 & 60% brighter than a standard H4! This is achieved by mucking around with the gasses inside the bulb. They produce a really white light, whilst drawing no more current than a standard bulb....Another added bonus being that the beggar that has just cut you up at night is REALLY sorry should you happen to leave the main beam on for a minute or two due to the shock of the near miss!!
Spanner Man
NEW HEADLIGHT BULBS Quiff Wichard Bikes - Talk & Issues 7 10-07-12 09:55 PM
Curvy Faired Headlight Bulbs fenris SV Talk, Tuning & Tweaking 7 26-02-08 05:20 PM
lidl headlight bulbs hovis Bikes - Talk & Issues 9 05-06-07 03:14 PM
Aftermarket Headlight Bulbs colinbal4 SV Ecosse 12 11-11-06 12:11 PM
Headlight bulbs stick Bikes - Talk & Issues 2 27-02-05 09:42 PM
