Old 06-08-05, 07:57 PM   #1
chewy22
Default Tie bars dog bones question
Ok I know this one has been done to death but I keep getting e-mail asking if I make them for the 650 ranges. And it seems daft of me not to offer this service as I already make them for the new SV1000 and they will be easy to make using the same jigs and cutting process. Question is what do you want or which way do most of you guys go up or down and by how much? Also someone here maybe able to answer this one are they the same on both generation bikes i.e. the 1999 bike that started this and the new shape SV650 Mine have a dogleg in them to fit around the lower part of the shock but the 650s don’t need this so I could get them done a little cheaper.
If someone is already covering this here I have no wish to step on their toes but I do have to keep replying to lots of e-mails regarding this one.
Old 06-08-05, 07:58 PM   #2
Iansv
I want to raise my rear end so if you make some smaller sized ones you got one buyer
K1
Old 06-08-05, 08:00 PM   #3
Scoobs
I'd like to lift the rear an inch or two. Never ridden another SV with this mod, but I wouldn't mind having a quicker turn in. Can't say how much I need cos I don't know.
How much? (roughly)
PS '99 SX
Old 06-08-05, 11:15 PM   #4
jon
I'd like to bump my rear up to + 2" or so... just more fun
Old 07-08-05, 07:41 AM   #5
richwill68
Hi Chewy!
The dog-bones on the first generation SV are flat; no dog leg so manufacture should be even easier!
Sorry, I have no idea how much people raise/lower their machines. I suggest that if you make them in inch or half inch increments people will have a wide range from which to choose. Either that or make to order...
Regards
Rich
Old 07-08-05, 01:57 PM   #6
chewy22
Ok I have had a look at the early model and the standard bones are 105mm between each bolt just need to work out the ratio to find out how much bigger or smaller I need to go to get the ride hights you need.
Old 07-08-05, 02:03 PM   #7
Grinch
well I'd rather loose a inch.. I've cut it out of the seat.... so how much lower can I go. Plus I have a zx636r shock to go on the adds that inch, so I'd like to cancel that out.
Old 07-08-05, 03:25 PM   #8
I wud buy some-
I know they are £25 from Js or somewhere similar??////
I wus liek to raise the backend a bit..for turning in etc...
I got some steel the right mm and had a go at makinsome !!-- was a poor effort..
£5 of steel and £10 of hacsaw blades and angle ginder discs!! so was false economy.!!
so....wen r ya makin em and r they gonna be £20 !!??
Old 08-08-05, 06:22 PM   #9
viner
I reckon I'd like to loose some height - half to one inch being about right. Why not make some adjustable ones - join the two ends with an adjustable screw thingy so that people can f..k about and settle their own rear ride height - just a thought!!!!!
broken bones question again kwak zzr Idle Banter 37 17-10-07 12:11 PM
For those that have broken bones-question Paws Idle Banter 55 29-09-07 09:11 AM
Dog Bones darrens_here SV Talk, Tuning & Tweaking 9 21-06-07 12:12 PM
SV650S bars for SV650 bars? MikeC SV Talk, Tuning & Tweaking 11 08-12-06 12:34 PM
Self made dog bones........material question svrash SV Talk, Tuning & Tweaking 26 12-06-06 09:18 PM
