Old 10-08-05, 02:55 PM   #1
Dante
Default Suspension/Shock setup advice please.
Hello - i've had my K5 SVS for a few months now and am now putting more miles on it (nearly 1200!).
The one thing i've noticed is that it handles better with a full tank of fuel in it than when empty or close to empty.
By this i mean it seems to feel more planted in the turns and less jittery when you nail it.
Can anyone tell me in non techy newbie terms what i need to do to the suspension setup to replicate this all the time?
Cheers fellas
Dan.
Old 10-08-05, 03:00 PM   #2
MarkyBoy
Keep the tank full!!!
sorry, couldnt resist!
Old 10-08-05, 03:05 PM   #3
Dante
Not as daft as it sounds and is my currently employed method of suspension correction - but i was thinking more long term and for journeys beyond 50 miles!
Old 10-08-05, 03:08 PM   #4
Flamin_Squirrel
How much to you weigh?
Old 10-08-05, 03:09 PM   #5
Dante
12 stone summat.
Old 10-08-05, 03:12 PM   #6
Dante
and i would guess that 15 litres of fuel would weigh 35lbs (1litre = 1kg or 2.2lbs).
I see where you're going - very scientific!
Old 10-08-05, 03:12 PM   #7
Flamin_Squirrel
Not too heavy then...
I assume it feels like the bike's skipping over bumps? It may be you've got too much preload. The manual will tell you how to alter this.
Old 10-08-05, 03:17 PM   #8
Dante
Thanks FS - i'll RTFM and see if i cant try lessening the preload for starters.
Dan
Old 10-08-05, 03:27 PM   #9
MarkyBoy
to adjust the preload you simply turn the screws on top of the yokes, default factory setting is on 3 and it goes from 1 (right in) to 5 (right out), im a fat biffer so Ive wound them right in and its much better, so I assume you need to wind them out.
Old 10-08-05, 03:39 PM   #10
thor
I need to sort mine out too. The rear's too stiff, and the damping on the front is too, but not the compression!
Jordan, can I blag a ride n your bike sometime? I'd like to see how the power remap changes things.
Suspension setup explained. plowsie Bikes - Talk & Issues 4 21-01-09 02:29 PM
Suspension setup? neillfergie SV Talk, Tuning & Tweaking 7 10-06-08 03:15 PM
Good Suspension Setup G SV Talk, Tuning & Tweaking 44 28-08-07 08:29 PM
Changing the Suspension setup w.steele SV Talk, Tuning & Tweaking 15 16-01-06 11:05 AM
SV Suspension setup markfc SV Talk, Tuning & Tweaking 16 14-03-05 09:09 PM
