Old 17-08-05, 08:58 PM   #1
mario
Default Seat off???
Hi there,
Just bought my new Sv650k5 however despite the mechanic telling me how to remove the seat i can't get it off Can anyone tell me how to get it off please? The pillion seat is easy by key but its the main seat i cant sus out
Many Thanks
Mark
Old 17-08-05, 09:06 PM   #2
chazzyb
On a curvy SV (<=K2), you pop the trim clips holding the rear of the panels below the seat, undo the hex socket 'mushroom' head bolts, this reveals the larger hex socket bolts for the seat - one either side.
Old 17-08-05, 09:08 PM   #3
Using the 4mm allen key you'll find in the toolkit remove the panels underneath the seat, when the bolt is out the panel is held by a couple of pegs in rubber grommets, be careful as you wiggle them out, broken ones aren't unknown.
When the panels are off, you'll see two 6mm allen bolts - one either side - take them out and the seat will come free.
Old 17-08-05, 09:18 PM   #4
mario
I'll give that a try tomorrow!
Thanks very much
Mark
Old 18-08-05, 08:08 AM   #5
thor
Is this all detailed in the manual? Look for the bit about checking the battery levels.
Also, you can find pdfs of the full service manual on the main site.
http://www.sv650.org/sv_manuals.htm
Old 18-08-05, 08:09 AM   #6
MavUK
I broke one on my curvy when fitting my scottoiler... Hateful clips... Now held in place by the allen bolt alone - anyone know if this is bad?
Old 18-08-05, 08:15 AM   #7
Viney
always made me laugh...its a sealed battery...well mine was!
Old 18-08-05, 08:18 AM   #8
thor
Of course, I wrote that post without ever having checked my battery...
However, should it have been replaced with one that isn't sealed, you would have to lift the seat.
Either way, I'm sure it's in the manual somewhere. I don't have it to hand so I can't confirm, but it's definately in the service manuals somewhere!
Old 18-08-05, 08:26 AM   #9
Viney
You are correct, it is in the manual.
Old 18-08-05, 08:33 AM   #10
chazzyb
I always lift the seat - and put it down again afterwards.
The possible problem I see with using a non-sealed wet battery (on a curvy at least) is that the battery isn't mounted flat! Besides, who wants to have to disconnect it and pull it out to check the electrolyte level?
Is 650 seat the same fitting as the 1000 seat ? genesismike SV Talk, Tuning & Tweaking 8 05-05-09 06:11 PM
Gel Seat & Yellow Seat Cowl - just put them on ebay mike_avfc For Sale - SV's and SV related items 8 06-10-08 06:19 PM
My bike and other bits for sale-end can,seat cowl,rear seat and others monkey For Sale - SV's and SV related items 1 10-08-07 12:26 PM
K6 - New riders seat, New full power ECU, Blue seat cowl & owners manual ivantate For Sale - SV's and SV related items 15 19-06-07 09:44 PM
pillion seat and a silver seat cowl for K3 lukemillar Stuff Wanted 2 08-02-06 06:01 PM
