Hi
Does any one know of a resistor in the ignition switch or ignition circuit that acts as an immobiliser?? I am having trouble starting. It is like the ignition circuit is immobilised. Everything else is ok???? |
fantabulas
Is it a curvy or pointy?
My Flickr photos |
Sorry if i'm telling you how to suck eggs but you need to have the cluch pulled in
The Sick Man
Kill Switch Off, Side Stand Up, Clutch In, Start.......
If no broom then your stuffed.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#5 | |
fantabulas
Just had a PM from Jocky
As TSM say's...
My Flickr photos |
fantabulas
Here is the starter circuit for your modle bike.
hope this helps... and no there's no resister in the circuit, but there is Sidestand switch and the clutch switch as the start button + a 30amp fuse.
My Flickr photos |
Boy it did my noodle for 2 days
![]() ![]() ![]() I would guess thats why there's a hand book ![]() |
mine was the kill switch, didn't realise I'd knocked it. spent 1/2 hour pulling my hair out!
#9 |
Jocky, it is possible if not probable that there is a resistor in the ignition barrel itself. It's an anti hotwire measure Suzuki used in the bandit/gsxr etc. and I'd be very surprised if the SV doesn't use the same method.
However unless you're trying to hotwire this bike of 'yours' ![]() Know anyone near u with a curvy SV? Get a loan of their CDI, swap them and see if that is the problem. |
#10 |
Hi
Thanks for the info regarding the resistor in the ignition barrel. This may be my problem as the bike is a stolen recovered. The ignition was missing when i got the bike and i have replaced it with one from a breakers. I am told it is the correct ignition. I will check. Do you know the size of resistor and its exact location???? Cheers Jocky |
k5 ignition switch removal | twonky | SV Talk, Tuning & Tweaking | 3 | 17-07-08 08:41 AM |
removing the ignition switch? | maxwell | SV Talk, Tuning & Tweaking | 12 | 24-02-08 08:32 PM |
Ignition barrel resistor help?? Which wire?? | Michaelreddo | SV Talk, Tuning & Tweaking | 1 | 28-04-06 12:43 PM |
Ignition Switch | Tris | SV Talk, Tuning & Tweaking | 0 | 12-04-06 11:24 AM |
Ignition switch compatability | kern0079 | SV Talk, Tuning & Tweaking | 1 | 11-07-05 10:36 PM |
