Old 07-09-05, 08:44 PM   #1
trick
Default GSXR USD Forks on 2003 sv650s
someone else posted a thread on here not too long ago but i cant find it. it had a list of which gsxr's are compatible with the sv650. just wanted to know which ones. thanks a lot
anyone else dont this swap? improvements, differences, how much did it cost and where did you get your parts from?
thanks a lot
TRICK
Old 07-09-05, 11:22 PM   #2
On an 03, it's pretty straightforward- more or less a straight swap for any Y-onwards 750 or K1- thou. Some finagling with yokes is all. Some work betetr than others, but once you've got a set of 50mm yokes, you can wedge loads of different front ends in. Like mine, with its SRAD yokes but K2 forks and SRAD wheel. GSXRs have really good interchangability like that...
Old 08-09-05, 04:50 PM   #3
trick
so does that mean that i can put any forks from a gsxr 750/1000 on an 03 sv650s. as long as the forks are from a bike 2000+? also, can i ue the stock sv yokes or would i need to get a new custom yoke made. also would it be possible to get a complete gsxr front end and just change the spindle?
thanks again,
TRICK
Old 08-09-05, 05:27 PM   #4
You need to use either a GSXR yoke or a custom one (well, or some other yokes but mainly GSXR). You can't drill out SV ones to take the bigger forks, they're too small.
With injected bikes, I'm not sure what the deal is with the stem... You might not need to change anything in fact. Drop Zoran a line, he'll keep you straight with that...
You can use older forks than that- SRAD 750 forks (96 onwards) are pretty much the same as Y-K2 forks apparently. But personalyl I'd rather use more recent bits just because they're more likely to be in good nick.
Old 08-09-05, 05:31 PM   #5
Mike1234
Use the GSXR top and bottom yokes.
Allegedly the GSXR bearings have the same external size as the SV so should fit straight in.
Haven't checked if the length of the centre stem is correct yet but it can't be to hard to work out.
I have a set of GSXR600K4 forks and yokes sitting here if you need any measurements taken.
Old 08-09-05, 06:37 PM   #6
trick
thanks for that man, you looking to sell that gsxr set up u got there? if not i might look on ebay and see what that turns up. anyway, if you can fidn out the measurements i need that would be a great help. thanks again
TRICK
Old 08-09-05, 07:18 PM   #7
Mike1234
Just waiting to hear whether I have managed to acquire another one. Will let you know if I have one spare.
Old 09-09-05, 12:39 AM   #8
trick
nice one mate, you got a complete set then (forks and yokes)? would be very interested in this if you have. what year gsxr did the front end come from andwhat model is it (750/1000)? thank again mate
TRICK
Old 09-09-05, 08:26 AM   #9
Mike1234
Forks, Yokes, Calipers & Axle from a GSXR600K4 (2004).
Old 09-09-05, 09:06 AM   #10
Carsick
uthaug did a complete front end swap with GSXR750K4 bits. The bearing is the same and the stem was the right length. He literally just bought a new front end, though, rather than collecting one.
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
GSXR Forks tactcom7 Stuff Wanted 0 05-04-09 01:16 PM
K7 GSXR 600/750 or K8 GSXR 1000 Forks shelleyamy SV Talk, Tuning & Tweaking 17 04-07-08 07:51 AM
which GSXR for forks svrash SV Talk, Tuning & Tweaking 29 15-02-06 09:15 AM
2003 GSXR 1000 headlight on 2003 SV footfukinmasta SV Talk, Tuning & Tweaking 0 22-01-06 08:27 PM
