Old 08-09-05, 04:28 PM   #1
stewboy
Default Bungs , Mushrooms
Hi all anyone got any idea where i can get some bungs fitted ( dont trust myself to do it)...... cheers
O! and are they worth it. ???
Old 08-09-05, 04:49 PM   #2
Noufy
Hi, most will say they are well worth it. I have the Suzuki ones and they have been very handy when I dropped the bike few weeks ago, at a stand still
It is not too difficult to do, although I didnt do mine either. If you can find someone near you to help/do it for you else go to your dealership. Metropolis on the Albert Embankment are very helpful, bought my bike from them. Dunno how far it is for you though.
Old 08-09-05, 04:54 PM   #3
Itching 2 go
what part of se london are you in? I can name several places that will do it for you I can also name places you 'd be better off not using but I wont do this publically ok?
Old 08-09-05, 05:17 PM   #4
Liam
I'm not mechanically minded at all, and this was the first ever job I did on mine. If you don't have full fairings then there is no drilling involved, it's surprisingly easy and I'd encourage you to have a go; it certainly started building up my mechanical confidence, which is useful as a bike owner seeing how many bits you should be checking occasionally yourself.
Liam
Tools
Two socket wrenches, or one socket and a torque wrench
Two sockets, 17mm to remove existing bolt, whatever necessary size to do new bolt if different (I used R&G's crash bungs, work really well, needs 3/4" sockets to tighten)
Method
Put one socket on each side, hold one side steady and spin the other anti-clockwise to loosen
Repeat on other side.
Undo one of the nuts completely
Pull out engine bolt
(From this point a good bung set will have instructions)
Put one nut on crash bung bolt and hand tighten, leaving off plastic crash part
Put new bolt through engine
Hand tighten other nut
Put socket wrenches back on both nuts
Tighten clockwise
Screw in plastic crash parts
Hey presto - it really is this simple. Good luck!
Old 08-09-05, 05:52 PM   #5
independentphoto
Don't get the Suzuki ones since you have full lowers on. I specified R&G for my bike since they have a good rep and I'd read that the Suzi ones are meant to be useless on fairings - one drop and they're smashed.
I picked up my bike (SK5) from having it's service done and lowers & bungs fitted only to notice that they were the wrong ones when I got home. A call to the dealer revealed that it was a simple ****-up and they will be changed for the R&Gs.
Looking at the Suzi bungs fitted, I'm quite alarmed at the design. The plastic "slider" bolts to a curved steel rod which fastens to a frame bolt. Upon impact, it would bend acting as a lever and pull the fairing in with it, smashing the plastics. EXPENSIVE!!
R&G bungs fit using a solid aluminium machined mounting block/spacer that bridges 2 mounting points. The plastic reel then mounts to the centre of this, spreading the load centrally and without deflection. Should be much more effective.
Good luck,
Garry
Old 08-09-05, 06:12 PM   #6
Kylie
Kylie's Avatar
Not so, I have a K3 with OE lower fairings and OE bungs, looks like this http://www.suzuki-gb.co.uk/partdetail.asp?id=240&m=24. To my shame I have dropped the bike 3 times since I got it a month back, all under 5mph, once to the left and twice to the right. Only damage has been broken indicator lens(which is fair enough) and some small scratches on bar ends, exhaust and lower fairing. No smashing involved, and saved me a fortune.
Kylie is offline   Reply With Quote
Old 08-09-05, 07:18 PM   #7
Iain51
R&G RULE!
@ knowing this first hand!
Old 08-09-05, 07:25 PM   #8
ive got the motorax DHM's for £40 on my k3 and fitted them myself, ive herd people on here say they arnt much cop but i aint dropped it yet to find out.
Old 08-09-05, 07:27 PM   #9
hall13uk
Default Re: Bungs , Mushrooms
R&Gs rule fella
Old 08-09-05, 07:41 PM   #10
jenni
R+G's are well worth the £70
dropped mine on the left. lhs murror popped out- no other damage!!
got rear ended, dropped to the right, rhs fairing cracked but thats it!
mushrooms Svkid Bikes - Talk & Issues 5 19-02-09 10:24 PM
Crash bungs/mushrooms/protectors questions, lots of oldjack SV Talk, Tuning & Tweaking 23 23-11-06 12:19 PM
Mushrooms Duck-man SV Talk, Tuning & Tweaking 11 04-10-06 07:41 AM
Crash Mushrooms/Bungs with lowers? moodyman SV Talk, Tuning & Tweaking 2 26-01-05 08:33 PM
Where to buy R&G Mushrooms? Bagpuss SV Talk, Tuning & Tweaking 17 14-10-04 06:29 PM
