Old 11-11-05, 09:47 AM   #1
Yarodia
Default Gear Position Sensor
I found this http://www.bluegauges.com/gearindicatorplans.htm I have wanted to make one of these since I got the bike and now I know how Only problem is that it needs to be wired up to the Gear Position Sensor, and it says on the site "I believe most Suzuki models 1996 and up have one" is this true and if so does anyone know where it is?
I want to fit it to a 2001 S model.
If I can make one i'll post up a tutorial when it's done
Old 11-11-05, 01:26 PM   #2
haggis
It's built into part of your ECU, I think. Don't have my manual at the moment to check, but the ECU needs to know 2nd and 3rd to do the retarding in those gears. You'll have to chop one up to do this mod and I imagine if you did the cheap delimiter mod then this guy's idea won't work. I could be wrong.
Do give us a progress report.
Old 11-11-05, 03:29 PM   #3
svpilot
Hmmmm,
This is interesting
I'm a pcb designer, I could knock up a proper PCB for this. Using a company such as www.pcbpool.com I could get a few made quite cheaply.
Hmmm I'm off to look at that circuit...
Old 11-11-05, 04:59 PM   #4
haggis
It wouldn't take a genius to convert that into a 7 segment display which would be better as a readout. Maybe add a rev bar display in the same unit, then it would be perfect.
Old 11-11-05, 05:24 PM   #5
Brucey
I would not bother with that old circuit its very crude as it doesnt put out the previous gear light so in sixth gera all leds are on same fro neutral I did a better design using three LM339s which works a lot better.
Or better still use a Pic chip if anybody is interested I can supply a pre programmed Pic to do whatever you want Seven Segment or seperate Leds.
And this wont work on a non Fuel Injected SV650 as the GPS is differant.
Old 11-11-05, 07:42 PM   #6
Yarodia
I havent done TRE trick on mine, and not that bothered about it really, although if someone could come up with a better circuit incorporating one i'd go for it
svpilot, that's a cool idea. Some help on this would be great as I was planning to just bump my way through, anyway i'm willing to use my bike as a test subject, so if you get any ideas just let me know
I thought about the 7 segment display, but I personally want the LED's. I'm going to cut into the dash and mount the unit behind with the light's sticking through like so...
Like I said any help would be greatly appreciated, so keep the replies commin, and thanks to all who've replied so far
Old 12-11-05, 06:21 AM   #7
neuone
Brucey, could I get a copy of the schematic with the LM339s? What kinda of output did you use? I found this:
http://www.gear-indicator.com/catalog/agora.cgi
and this:
http://www.geartronics.co.uk/suzuki.htm
but I don't want to pay $140 US or more... and I like having little projects.
Old 12-11-05, 08:09 PM   #8
Yarodia
Sorry for being stupid but which models does that include?Is it just the 2003+ bikes that were fuel injected or did they introduce it earlier?
If it would work on a 2001 SVS i'll have one please
Old 12-11-05, 08:20 PM   #9
Carsick
FI came in on 03.
Old 12-11-05, 08:30 PM   #10
Yarodia
Bugger!
throttle position sensor Bibio SV Talk, Tuning & Tweaking 9 20-10-08 02:49 AM
Pointy throttle position sensor svdemon Stuff Wanted 9 02-09-08 07:50 PM
K3 and up Gear Position Switch Brucey Stuff Wanted 2 21-05-07 07:51 PM
Throttle Position Sensor tricky SV Talk, Tuning & Tweaking 10 08-06-06 07:16 PM
Bike cuts out.... tip over position sensor how does it work? ianofbhills SV Talk, Tuning & Tweaking 9 04-05-06 10:03 AM
