Old 23-11-05, 08:21 AM   #1
dclifford
Default Able to remove key with bike running
Can any body else take the key from the bike and still have the bike running. I think it is unusual.
Old 23-11-05, 09:13 AM   #2
Not that unusual - my Kawasaki is the same, the tumblers of the ignition lock are worn.
Old 23-11-05, 09:42 AM   #3
thor
Just remember to turn it before removing it!
Old 23-11-05, 12:07 PM   #4
minky
Have this on my Katana's, tried WD40 in the lock and it worked to a degree
but ended up buying mew ignition barrels
Old 23-11-05, 03:08 PM   #5
TSM
The Sick Man
TSM's Avatar
My dad had that on his car, it was a bit of both, the key was cut correctly but overall worn out and the lock is old. If he used an original key that was hardly used the key would not come out though.
Old 23-11-05, 09:00 PM   #6
dirtydog
Knob faced knobster
dirtydog's Avatar
mine did exactly the same tjhing managed to get a new ignition barrel on a warranty claim
2011 Speed Triple 1050
Old 23-11-05, 11:29 PM   #7
AlfBoy
Doesn't having a worn lock make your bike more vunerable to theft? Like couldn't some guy take a crowbar, or a big straight-bladed screw driver and turn on your bike? Seems like it would.
Old 24-11-05, 12:28 AM   #8
sprocket
Can remove the key on my gfs TRX850, comes in handy sometimes though
Old 24-11-05, 08:32 AM   #9
It doesn't make as big a difference as you might think, the locks aren't that good to start with.
Sadly, no more so than with an unworn lock.
Unless you're going to force the lock, with a screwdriver etc as you suggest, then even when worn you'll still need a key which will physically fit the lock form, the difference being that when the tumblers are worn there is a greater variety of keys that will now fit and turn it, but then if you rely on the ignition lock alone it's never going to be very scure anyway. I mean this, the standard locks really aren't that good.
Old 24-11-05, 09:30 AM   #10
AlfBoy
Yeah I didn't think so. It seems it does not take much to steal a motorcycle.
Running in a new SV? Baz SV Talk, Tuning & Tweaking 32 08-09-14 07:51 PM
Running a bike that isn't vertical. TheStudent Bikes - Talk & Issues 10 09-07-07 06:18 PM
running in a new bike steveg SV Talk, Tuning & Tweaking 14 02-02-06 12:14 PM
Bike Running Bad. PLEASE HELP Scoobs SV Talk, Tuning & Tweaking 7 02-03-05 03:06 PM
bike running well again Iansv The Essex Lounge 9 31-12-04 09:10 AM
