Old 01-12-05, 07:57 PM   #1
stumpy1
Default speedo problems 650 04
hi guys how goes it ? just wanting to know if any one has had a problem with there electronic speedo (650 04) model as mine has started to act up
just thought i would ask.
cheers
stumpy
Old 01-12-05, 09:41 PM   #2
trouble
Default stumpy
Bought the 05 model a few weeks ago and had to take it back because the speedo wasn't working. Had to be replaced. Strangely enough Mr's speedo on his triumph daytona 955 has been playing up.
Old 02-12-05, 09:26 AM   #3
Captain Nemo
mines ok stumpy, what do you mean by "act up"
Old 02-12-05, 10:02 AM   #4
Flamin_Squirrel
Default Re: speedo problems 650 04
cheers
stumpy
Have you had the front wheel off lately?
Old 02-12-05, 10:04 AM   #5
BillyC
BillyC's Avatar
cheers
stumpy
To expand on Flaming's cryptic post...
... the most likely thing, without a doubt, is that the speedo sensor in the front wheel has broken. They're very fragile, and once they go, they go!
Such is my confidence in this problem that I'd almost recommend that you go and buy a new one speculatively - they're about £10 I think
At least that way, you'll only have to take the wheel off once!
Old 02-12-05, 10:32 AM   #6
PoRk ChOp
If it's the problem where the displayed speed is very eratic and sometimes tells you that your doing 800mph then goes straight back to zero then 50mph then zero and then works as normal and then goes loopy again, well if thats the problem I had the same one not so long back.
The front wheel had never been off the bike and it turned out to be a dodgy connection behind the head stock.
The problem was solved by lifting the tank and giving the connectors a clean and refitting them, problem solved.
Old 04-12-05, 01:29 PM   #7
stumpy1
hi guys front wheel has been off by 4/5 weeks ago for new tyre, took it back to the dealer to have a look and they have found out that there is a problem with some of the sv speedo sensers on 650/1000 models so suzuki are aware of the problem, so getting it sorted under warranty.
cheers guys happy motoring
stumpy
speedo problems Stoppo Bikes - Talk & Issues 21 31-01-09 07:34 PM
Speedo problems bezsv Bikes - Talk & Issues 11 18-10-08 04:28 PM
Speedo Problems trevrobwhite SV Talk, Tuning & Tweaking 35 13-05-08 12:18 PM
Speedo problems K3 Skidlid SV Talk, Tuning & Tweaking 25 03-07-06 09:23 PM
Speedo problems goof SV Talk, Tuning & Tweaking 2 09-08-05 08:47 PM
