Old 05-12-05, 09:40 PM   #1
JonnyBoy
Default interchangeable parts for SV and... ?
Hi,
I'm recovering my bike (99 SVx) from a crash I had and right now I'm on a quest for parts. Do you know what other bikes share the SV front end?
I'm after wheel rim, forks (or just the inner tubes) and radiator.
For example, Will the Bandit 600 rim fit?
Thanks
Udi
Old 05-12-05, 10:05 PM   #2
TSM
The Sick Man
TSM's Avatar
have you looked at just getting the front converted up to a GSXR USD forks?
I think you could use a pair of forks from a K3+ but you would need a K3+ wheel & disks and front hugger and spindle. Dont quote me on that though. Anybody know if this is possible??
Radiator, nearly any radiator can be made to fit & work. AFAIK all curvey radiators will work on each other, only diffrence is the faired & unfaired. Cant see why the K3+ radiators will not work, may need a bit of modding on the pipe work plus if you have the faired version you may have other problems.
Old 05-12-05, 10:25 PM   #3
haggis
The K series bandit6 front end is nicked straight off the curvy SV!
If you can get one complete it's a decent option as they might be nearly new whereas a curvy front end is at least 3 yrs old now.
Earlier bandits were a 110 front tyre, so avoid.
K series forks, wheel, spindle, calipers and bottom yoke are shared, top yokes are not the same AFAIK. Muddy is a wee bit different styled but you'd hardly notice. However the bandit is some 40kgs heavier so the springs are not the same, you'd hope!
As TSM says the rad option depends on whether your fussed about the style. I assume by SVx you mean naked, so it matters less than on a faired. The pointy rad is a bit different though and their brackets are bound to be re-designed.
Old 05-12-05, 11:25 PM   #4
I've got a set of forks in the garage... Check out For Sale.
Old 05-12-05, 11:52 PM   #5
JonnyBoy
Yep, it's the naked one.
Now just to make sure I got it right, I can fit a 2000 Bandit 600 or (later model) wheel rim? I was scanning the web for the SV parts but what I've found was way to pricey
northwind, sent you a PM...
Old 08-12-05, 05:18 PM   #6
JonnyBoy
I've found the fork inner tubes from a "sv650 k4 2005".
Mine is 99 and a suzuki dealer advised me that it's a diffrent part number for the 05.
How can I check if it will fit?
I mean, how can I get the spec for those tubes?
Old 08-12-05, 05:33 PM   #7
Brucey
The fork legs are larger dia. from K3 on so unless you replace the legs and yokes they are not going to fit.
Old 08-12-05, 08:09 PM   #8
haggis
How knacked are the fork legs? You could maybe get them straightened.
I'm considering this option, as I have a set that are only slightly off straight and no pitting or chrome gone so seems a shame to bin 'em. I've not got a quote for this but heard £30 a leg is about the norm.
Especially as '02 sets of forks go on eby for the price of two new stanchions. Then there's oil and seals......
are yokes interchangeable twonky SV Talk, Tuning & Tweaking 2 12-01-08 12:19 PM
Are curvy & pointy chain guards interchangeable>? DarrenSV650S SV Talk, Tuning & Tweaking 3 03-06-07 07:59 AM
Are Belly Pans interchangeable between SV1000's & Pointy Stu SV Talk, Tuning & Tweaking 2 25-09-06 12:32 PM
SV650s and GSXR600 interchangeable parts - anyone? Jimmer Bikes - Talk & Issues 6 24-03-06 02:53 PM
Interchangeable Stuff - Rear Sets Mike1234 SV Talk, Tuning & Tweaking 2 07-12-04 08:57 PM
