my Svs just had a masive service everything done to it tapets brake fluid and even the tyer presures!
but! on my way to work sometimes between 456k revs she kinda spluters and dosent idel very wel when i pull over leave the choke on for a bit she seems ok just a bit hesitant :S ![]() ![]() ![]() is this my first experiance of carb iceing ??? its not realy realy cold just cold lol oh and for got its kinda like the front pot is cuting out like it dose in the rain but its not .... or is it??? ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
The Sick Man
456k revs,
![]() were the carbs balanced??
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#3 | |
carb icing is not about how cold the ambient temp is
with the right dew point conditions you can get carb icing at almost any temp. the velicity of the air rushing into the carb cools it down and moisture in the air will form ice crystals if it coos the carb to a temp that is below freezing |
Time to stick addititve in tank me thinks, ASAP!
#6 | |
Sounds like it might be
Is quickest & easiest thing to check, just add some & find out within first few miles usually, anything like a small amount of fuel injection cleaner or go get bottle of FST
Coughing SV | tricky | SV Talk, Tuning & Tweaking | 2 | 20-05-05 10:25 AM |
