Old 08-12-05, 10:34 PM   #1
rubbermonkey
Default Wanted: Indicator connection blocks.
Hope someone can help.
I've fitted some mini indicators but the connection plugs/block from the stock indicators fell apart when i took the fairing off.
I'm after the 2 connection blocks that fit together from the stock indicator to the bikes electrial system with some wire either end so i can solder them back onto the existing loom.
Could get bullet connectors but want a neat and tidy job.
anyone help cash waiting.
cheers
steve/rubba
Old 08-12-05, 10:39 PM   #2
svrash
You can get heat shrink bullet connectors
just haven't found them yet
Old 08-12-05, 10:43 PM   #3
TSM
The Sick Man
TSM's Avatar
go to halfords they do them in a small box, they are red or blue depending on the amps used.
Old 08-12-05, 11:04 PM   #4
hall13uk
spot on, thats where i went, when i needed them for my last bike
Old 09-12-05, 08:16 AM   #5
Errr...wasn't the request for standard connectors, not crimps?
Old 09-12-05, 10:38 AM   #6
Viney
Correct. Bless them, they havent quite got round to the reading classes yet
You can get an alternitve type connector like whats used on remote controlled cars. These use crimp type pins that go into a plastic block, make and female. These may be slighty better than bullect connectors. Check out your local model shop.
Old 09-12-05, 11:38 AM   #7
thor
Those block connectors are much better than bullet ones, because you can't connect the polarity wrong, and the clip in so they don't come apart due to vibration.
Just like the OEM ones then!
BTW, do not buy them at maplins as they are pre wired and cost too much.
Old 09-12-05, 11:22 PM   #8
svrash
Found some
Demon tweeks do them in there car (motorsport)catalogue
And fuse boxs too That'll be handy
Mini Indicator wanted Whynot Stuff Wanted 3 03-10-08 05:18 PM
right indicator wanted blakey Stuff Wanted 2 07-06-08 07:28 AM
Indicator ideas wanted please svrash SV Talk, Tuning & Tweaking 16 11-05-07 09:20 AM
Indicator wanted seandixie Stuff Wanted 3 05-06-06 04:30 PM
Something about little blocks..... Caddy2000 Idle Banter 9 11-04-06 08:42 PM
