Old 12-12-05, 02:59 PM   #1
Mark_h
Mark_h's Avatar
Default So where did you fix your charging socket?
Following the advice of all the experts on this site I have invested in an Optimate and found the lead you fix to the bike too short to put it where I had originally planned to put it in the gap where the grab rail used to be.
So I though a quick canvas of thoughts before I stick it somewhere and find out it gets cooked, flooded, shorted, forgotten about or otherwise found to be a stupid place to put it.
Obvious choices seem to be:-
1) Under the pillion seat but have to take seat off each time to charge.
2) Just in front of airbox cover side plate thingy but may get too hot/wet
3) Wedged under the side of the front seat
4) Between the front seat and the step up to the pillion but may get squashed when 15 stone of idiot slams into it each time right hand gets carried away.
5) Extend the wiring and put it where I had originally planned to put it in the first place.
Opinions gratefully received. I do not really want to over engineer a solution by cutting out square holes in cover plates or anything else that required finesse to not look like a dogs breakfast.
Cheers,
Mark
Old 12-12-05, 03:13 PM   #2
TSM
The Sick Man
TSM's Avatar
Just put it behind one of the side panels.
Old 12-12-05, 04:39 PM   #3
Reckless Rat
Mines:
Taking the seat off is a 2 second job, and it keeps things out of the way!
RR
Old 12-12-05, 05:00 PM   #4
perra
Under the seat cowl works for me
If i put the wiring were the helmet hook is i can keep
the seat cowl on when charging!
Old 12-12-05, 05:16 PM   #5
Spiderman
Where the hell am I?
Spiderman's Avatar
mines behind the plastic grill bit on the rhs. Means i have to undo the allan bolt to get to it.
But the guy who owned the bike before me had routed it there so i just use it.
Old 12-12-05, 06:13 PM   #6
Biker Biggles
Biker Biggles's Avatar
Under the pillion seat for me.It's not a problem.
Old 16-12-05, 01:17 AM   #7
Oneiros
If you've got the pointy and done as a lot of people have and locked the toolkit under the seat then you have a handy little waterproof(ish) compartment to mount it in.
Old 17-12-05, 05:04 PM   #8
Mine sort of dangles out the side. Need to do something about that
what size socket? kwak zzr SV Talk, Tuning & Tweaking 13 10-05-09 07:16 PM
Socket sets dmracing SV Talk, Tuning & Tweaking 35 26-08-07 11:08 PM
Socket AM2 Motherboards M65 Idle Banter 8 28-11-06 11:31 PM
What size socket cuffy SV Talk, Tuning & Tweaking 4 19-07-06 01:27 PM
Socket set question??? Cloggsy Idle Banter 5 02-03-06 12:17 PM
