Old 26-12-05, 01:56 PM   #1
suzsv650
Default scottoiler suction tube thingi
whare do i put it ??? i need to create the vacume but what pipe whare from help!!!
Old 26-12-05, 02:14 PM   #2
suzsv650
oh its a curvey to !
Old 26-12-05, 02:14 PM   #3
suzsv650
Old 26-12-05, 05:37 PM   #4
Yarodia
lift the tank and look for the pipes on the right hand side of the bike. You will need to cut through the vacuum pipe and insert the T connector that came with the scottoiler kit like so...
Old 26-12-05, 05:37 PM   #5
andyaikido
I think you might have to cut a tube and use the white 't' piece but i'm not 100% on that as mines a pointy. Go on the scottoiler website or give them a ring, they were very helpful when i needed some assistance.
Old 26-12-05, 08:54 PM   #6
embee
embee's Avatar
I teed mine into the vac feed that goes to the fuel tap, but the fuel pump feed as per the photo above works fine.
Yes, as said you need to snip the pipe and fit the T-piece which comes with the kit.
SV Tube Lucas Photos 61 13-08-10 03:22 PM
Bar end bolts held in by suction? MiniMatt SV Talk, Tuning & Tweaking 4 18-03-08 06:43 PM
You Tube? -Ralph- Idle Banter 10 25-10-07 04:43 PM
You tube Moo Idle Banter 17 08-11-06 07:58 PM
rear brake arm thingi! suzsv650 SV Talk, Tuning & Tweaking 18 16-05-06 06:38 PM
