Old 29-12-05, 03:03 PM   #1
SteveH
Default Crap, broke me back brake.... I think
Pulled away with the disc lock on the back brake now I never really went mad as I was turning the bike . But I now have no back brake I can only see a bit of a mark on the disc and it does not look bent.
So what you think new brake disc or could I have knocked the brake out some how
Old 29-12-05, 07:30 PM   #2
The best way to tell is to simply use it and see if it wobbles... A bent disc shouldn't cause total loss of braking though. I take it you've tried pumping the lever a few times? Does it feel normal apart from not braking?
Old 29-12-05, 10:25 PM   #3
SteveH
Just feels very soft and i have to push my foot all the way down before i get anything, and yep tried my brake a feel times on the way home with no affect
Old 29-12-05, 10:28 PM   #4
amarko5
has it possibly cut the pipe feeding the cylinder
if not perhaps a good bleed will bring it back
check carefully that it has not cracked any part of the caliper or the retaining arm.
Old 29-12-05, 10:41 PM   #5
Or maybe whacked a bleed nipple? Something like that. Your symptoms wouldn't be caused by a bent disc.
Old 29-12-05, 11:36 PM   #6
TSM
The Sick Man
TSM's Avatar
If any of the above are the case, you will find that your brake lever travel should be extended further than before without any resistance. But you would have probably noticed brake fluid on the ground.
Old 30-12-05, 12:35 AM   #7
SteveH
Nope there is no fluid and I have to push all the way down to get any resistance at all and even then it's not very much
Old 30-12-05, 12:45 AM   #8
pingu
Yes I have seen this problem before on television.
This chap had to push the brake all the way down to the ground to stop at all. It never went on to explain the cause but you could mail him.....
FredFlintstone@cartoonnetwork.com
Sorry, couldn't help it On a serious note, just take it straight to the garage. Theres no point risking your neck just to save a few quid.
Old 30-12-05, 08:13 AM   #9
Peter Henry
Pingu...Very good mate!
Could the bang have made the pistons jam up in the caliper? They might somehow be slightly out of skew thus causing lots of pedal movement but little braking action?
It's only me but I would never ever place a disc lock on the back wheel as somehow it just seems far easier to forget about. You need it on the bike but as visible as possible,not only to yourself but potential thieves also.
Hope the p`roblem is not too grave mate.
Old 30-12-05, 09:17 AM   #10
Viney
Its an aprillia, what do ya expect?
Back brake clicking Jay1 SV Talk, Tuning & Tweaking 8 30-04-09 07:34 AM
Sticky Back Brake branny SV Talk, Tuning & Tweaking 36 03-11-08 06:30 PM
Do you use your Back brake? Berlin Bikes - Talk & Issues 55 03-09-07 02:08 PM
sticky back brake on yer bike Bikes - Talk & Issues 4 16-11-06 05:53 PM
Back brake not activating brake light. quikstu SV Talk, Tuning & Tweaking 3 19-06-06 04:05 PM
