05-01-06, 11:48 AM | #1 |
emergency indicators
hey guy had an accident and indictors on right side dont work bulbs are ok and so is fuse any ideas?
05-01-06, 12:19 PM | #2 |
Check the relay switch.
05-01-06, 02:06 PM | #3 |
There is a plastic connector behind the fairing that may have come loose. Its easy to see when you take the fairing off.
Basically the indicator has a 10cm wire on it that connects to another wire on the other side of the fairing. I assume its to allow easy removal of the fairing. |
05-01-06, 04:47 PM | #4 |
Sorry, didn't read your post properly. I thought none of the indicators worked If it's just the right side then take the fairng off as Diveboy said.
In case of emergency! | shifter | Bikes - Talk & Issues | 20 | 17-02-09 08:46 PM |
Tv total emergency | Kilted Ginger | Idle Banter | 18 | 16-01-09 05:17 PM |
Emergency Stop(pie)! | mitchbligh | Bikes - Talk & Issues | 29 | 20-05-08 01:51 PM |
Emergency help required | Stig | Thames Valley | 26 | 18-04-08 04:17 PM |
Re: Emergency help required | mich | SV Talk, Tuning & Tweaking | 6 | 17-04-08 09:31 PM |
