Old 05-01-06, 03:27 PM   #1
Rob S (Yella)
Default Sv 650 K2 bits for nothing.
Hello all.
I'm having a clear out before I move and before I take all these SV650 bits to the dump I thought somebody might have a use for them.
All the bits on the table (PIC2) can be posted in a box and sent separate if you pay the cost of postage (about £10max) but all the other bulky bits will need to be collected. I have not got the time or inclination to wrap and post all the bits separate so it’s an all or nothing sort of deal.
Any takers.
If more than one person wants it then it goes to the highest bidder within 1 week of posting the post any proceeds going toward the site.
Below is a run down of the bits which I think is accurate but I have not checked so I won’t swear on it.
Carbs with throttle & choke cables Good condition/ standard jets fitted, with all cables attached (throttle/choke/idle speed) as well.
Rear shock Good condition, standard SV item, (not knackered) good as a spare?
screen Good condition, standard clear screen, (see other items for trim panels).
Grab rail Good condition not marked.
Clutch adjust(engine side) Good condition, clutch adjuster, fits under top sprocket cover.
Fork springs Good condition/ standard springs
dog bones Good condition/ rear suspension linkage (standard)
Top & Lower yokes Good condition, ignition lock removed.
Side stand & Switch Good condition
Tail plastics Good condition
Mud guard inc indicators & No plate bracket Good condition/ some cracks to inside, could be welded, not seen when fitted, complete with indicators and plate light.
Seat release mechanism Good condition, rear seat replace with cable.
Headlamp bulb cover Good condition/ rubber covers for the bulbs
Right clip-on Good condition/ graze to end of bar, not seen when bar end fitted.
Rear axle Good condition, standard SV naked or faired
Front sprocket cover Good condition
screen trim panels Good condition/ cover front fairing frame inside of mirrors.(see other items for screen)
Rear sub frame Good condition/ slight bent in metal cross member ( would hammer flat)
Water tank - battery connecting wires Good condition
Radiator Twisted/ NO LEAKS/ could be straightened a lot cheaper than getting a replacement!!!!
Rear light unit Good condition/ complete with both bulbs
Left clip-on with clutch lever & bar end Good condition/ only missing switchgear to complete.
Fork leg caps Good standard condition, chewed up yours? Get these.
Pair of chain tensioner (fit on swingarm) Good condition/ damaged yours? / here's another set.
TOOL KIT
FENDER EXTENDER
standard end can (sawn off)
And even some pics
Old 05-01-06, 03:51 PM   #2
gc350
Default bits
pm'd
Old 05-01-06, 07:10 PM   #3
enginedriver
PM sent
Old 06-01-06, 10:33 AM   #4
trudd
PM Sent
Old 06-01-06, 12:43 PM   #5
Rob S (Yella)
I've had quiet a few PMs asking for different bits so you will all have to be patient with me.
Hello Sarj, somebody else has also asked for the clutch adjuster so you might be out of luck I would have given it to you for the help you gave me but the other person who asked is also a regular Soho Massive type person.
Somebody asked if the fork caps were preload adjustable and I think the answer is no.
I wont be around till around from Sunday until next friday evening so I will look through them all then and work out who gets what. (unless somebody wants the job lot)
So busy, New home, new job, new knee
Old 24-01-06, 04:27 PM   #6
zunkus
I need svs footpegs and the top yoke if still available. Will pay for the costs of course.
Old 06-12-06, 03:57 PM   #7
plowsie
hi are there any bits still available?
Old 06-12-06, 04:27 PM   #8
suzsv650
ill have the
if its stil avalible
ill PM too!!
Old 06-12-06, 04:45 PM   #9
Steve226
PM'd
Old 06-12-06, 05:00 PM   #10
Rob S (Yella)
Whoa
Slow down you lot,
Sorry to disappoint but all the bits are long gone. This thread seems to have resurfaced with more interest today with replies and PM's than it did in January. Sorry but January was ages ago and it's all gone. Some even went to the tip as nobody seemed willing to come and get it and I just had to get rid of it.
All I have left is memories and I think a dented tank somewhere.
happy hunting
Need bits lots of bits sv650 2002 curvy K1 Nicky S Stuff Wanted 27 13-03-09 02:22 PM
various k5 650 bits fast-lad For Sale - SV's and SV related items 9 27-09-08 11:17 AM
SV Bits for sale (Bits left after breaking) Bikerz For Sale - SV's and SV related items 12 21-03-07 09:06 PM
SV bits for free and sale - WITH PHOTOS - FEW BITS LEFT lukemillar For Sale - SV's and SV related items 10 30-10-06 01:50 PM
Bits & Bobs Wanted - Any flash bits laying around??????? ugp Stuff Wanted 2 13-08-06 07:20 PM
