Going to change oil and oil filter, only to round the sump plug. I did use a socket set as well, not sure how hard these ruislip lads have thighten the bolt.
Is there any good trick to get the bolt off without having to take it up to the shop? Kindest regards, 127.0.0.1 |
It shouldn't be tightened to much as it threads into aluminium. You "were" turning it the right way weren't you?
ooops!.
Id take it somewhere that knows what they are doing now before you make any more mess. Seriously, you dont want to have to start drilling it out or risk cracking the sump!. I have seen that happen and his home service cost him £700 odd quid!. Are your tools upto the job?. If your socket is slightly rounded inside then it wont grip the plug tightly and cause it to round off. I am always doing that..hence why i ride the bike and steve works on it!!! ![]() |
Oh well, i wanted to avoid having to drag it all the way up to ruislip, but then i suppose i don't have much of a choise.
I was indeed turning it the right way. No i shan't be doing any drilling in there, since i don't have a drill, nor the knowledge. Well, to the suzuki shop it is then. ![]() |
Are you sure it was righty-tighty/lefty-loosey?
#6 | |
It's really easy to do it the wrong way when working upside down too... I always use a ratchet and set it before I go near the bike
#8 | |
Whenever working on something "upside down", I like to get underneath it if at all possible, so I won't fall foul to this. For this reason, I lie on my back when removing/fitting a sump plug. Fortunately, I learnt "the hard way" to do this at GCSE Design Technology as opposed to when working on a bike. ![]() |
#9 |
I`m an engineer and still have been known to get this wrong ( usually when you have an audience who are only too keen to point out your mistake ).
The socket you were using does it drive on the flats of the plug or the corners ( always best using the former on slightly worn nuts ). |
#10 |
Believe it or not, very tight drain plugs can, in my experience be freed by a firm "tap" with a well-aimed hammer
![]() Some of these hooligans think the plugs need to be "murdered" ![]() Good Luck, Garry ![]() |
Sump plug washer - where from? | pencil shavings | SV Talk, Tuning & Tweaking | 26 | 17-03-09 08:52 PM |
Sump plug bolt | Jimbo_Bimbo | SV Talk, Tuning & Tweaking | 28 | 04-09-08 12:42 AM |
Sump Plug Torque? | skov | SV Talk, Tuning & Tweaking | 2 | 27-02-08 08:38 PM |
Sump plug washer | yorkie_chris | SV Talk, Tuning & Tweaking | 3 | 29-09-07 10:44 AM |
Drilling Out Sump Plug? | UlsterSV | SV Talk, Tuning & Tweaking | 13 | 15-04-06 05:22 PM |
