Old 01-02-06, 04:01 PM   #1
Thaleshwar
Default Gear Shift Rod bent - Gear Changing problem
Hi,
Recently on one wet evening I slipped on a turning with my SV650S K2; when I lifted the bike I had problem bringing bike into neutral, and I could not see what was wrong as it was pretty dark. Somehow it came in neutral, I gave a start it did start and I could slide in first gear and drove home. On inspecting the damage next day I saw that gear shift rod was badly bent! how I could not know, I was wondering can I straighten the rod or do I need to replace it?
Once the rod is OK will my gear changing problem (I only can get into 1st gear) be sorted or there could be more damage to gear box?
I will really appreciate some helpful suggestion to my above problems.
Thanks & Regards
Old 01-02-06, 05:31 PM   #2
atko
sorry to hear about your off!
I've been in the same boat myself, you could try and straighten the bar again but it'll never be the same and all that effort may be useless if it still has problems shifting.
My opinion for peace of mind get it changed, good luck!
Old 01-02-06, 05:50 PM   #3
If it straightens with out breaking it'll be fine, the best way to do this would be to take it off and straighten it on a hard surface, with a hammer if necessary.
If you do remove it, note there is a reverse thread on one end.
Old 01-02-06, 05:52 PM   #4
TSM
The Sick Man
TSM's Avatar
Been there done that.
You will never feal right that its bent & you will allways notice it.
Other than that as SS said.
Old 01-02-06, 06:27 PM   #5
It'll be fine as long as it's straight, won't "feal" any different at all.
Old 01-02-06, 06:33 PM   #6
TSM
The Sick Man
TSM's Avatar
Thats not what i ment though.
Old 01-02-06, 07:49 PM   #7
Iansv
Mines been bent for over a year, I left it that way
Old 02-02-06, 06:18 PM   #8
Thaleshwar
Many Thanks for the helpful suggestion.. I think I have definitely come into right place..
This afternoon I picked up a new one it hardly cost £7.00 incl VAT, however the dealer indicated that its very likely that gear shift rod bent because when bike slipped the gear lever bent and came over under the rod.. so also picked up gear lever which was very quite expensive ad £38.00 but he agreed to take it back if not needed.. well weather permiting I shall try to mend this weekend...
Old 02-02-06, 06:56 PM   #9
Last Action Pimp
mine is bent and i dont have a problem and i bent it a year and a half ago
Old 02-02-06, 07:38 PM   #10
Thaleshwar
Yeah it may be true, but for me after the misshap (falling) for some reason I am not able to shift the gears apart from between 1st and neutral! the only way out for me is - some experience suggestion from this forum, replacing the damage bit and if nothing works then have no alternative but to take it to professionals and pay out heavy..
Help: 2nd to 1st gear changing problem AndyL SV Talk, Tuning & Tweaking 18 09-05-11 11:56 PM
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
Gear Changing Problem ricky_t SV Talk, Tuning & Tweaking 6 08-08-07 04:41 PM
