Old 10-02-06, 05:31 PM   #1
Freeloader
Default My bike wont idle.
Posted a little while ago that my bike seemed to cut out at the lights. It is a 1999 curvy.
Today i did i little test, i turned on my bike and went for a ride (not more than about 5-10 minutes).
To switch on the bike i used the choke, left it for about 30 seconds before moving off (and taking the choke off fully).
5 or 10 minutes later i returned to my drive and left the bike idling in neutral to open the gate and the bike stalled (The red warning light appeared).
I wheeled the bike into my drive and tryed the experiment again, pressing the tick button and leaving the bike to sit. Within 30-60 seconds the bike cuts out. It feels like the bike hasnt got enough revs, it seems to be very slow and sort of suffocating itself on idle.
Am i being a complete donut and should i leave my choke on for longer? Is the bike still cold?
Does my idle screw need adjusting?
Old 10-02-06, 05:35 PM   #2
Cloggsy
Default Re: My bike wont idle.
Sounds like it... Tick over should be anywhere between 1200 rpm & 1500 rpm (I think )
Old 10-02-06, 05:37 PM   #3
Scoobs
Manual says 1200, but I always found it "liked" it better at 1400.
Old 10-02-06, 05:54 PM   #4
thepyrofish
Mine does that too, but only happens when it's a really cold morning.
Old 10-02-06, 05:57 PM   #5
Freeloader
So where can i find the idle screw, shall i mess about with it, which way shall i turn it and by how much. Mine is idling at 1000 rpm tops. But it is very cold at the moment.
Any ideas?
Old 10-02-06, 06:06 PM   #6
Spiderman
Where the hell am I?
Spiderman's Avatar
Any ideas?
I normaly turn my revs up a touch in the cold weather and back down again when it warms up again.
The adjuster is on the left side of the bike. Look thru the frame under the fuel tank and you'll see a black knob attached to a long black tube/cable thing. Cant miss it cos it also has a crosshead screw in the centre to make it easier to adjust.
Cant really remember which way to turn it, but once your engine is warmed up as you desribed above just turn it this way and that and you'll soon see which is the right way.
hth
Old 10-02-06, 06:12 PM   #7
Freeloader
foundy foundy! Thanks guys!
I need help - Bike wont idle. TheShadow SV Talk, Tuning & Tweaking 13 08-10-08 02:05 PM
Bike wont start. I Need help please chunkytfg SV Talk, Tuning & Tweaking 3 13-03-08 11:53 PM
Why wont my bike rev? Peetee650 SV Talk, Tuning & Tweaking 4 14-06-07 05:02 PM
Help bike wont turn over aarond SV Talk, Tuning & Tweaking 6 06-05-07 03:08 PM
bike wont idle bcsv650s SV Talk, Tuning & Tweaking 5 12-05-06 04:37 PM
