Old 16-02-06, 05:37 PM   #1
JakeRS
Default Help Guys - Flooding?
Hi guys, for the past couple of days my bike's been playing up.
When riding the bike, at low revs it seems to flood when I try to pull away, it stutters and then comes back to life.
Immediate thoughts: crud in the carb(s)
flooding the carb(s)
misfiring cylinder?
What else might it be? I have a fender extenda, so its unlikely to be water, and both exhaust downpipes are equally hot so there's not one cylinder not working.
What else could it be?
Cheers guys (and girls)
Jake
Old 16-02-06, 05:42 PM   #2
jambo
jambo's Avatar
Check the condition of the plugs if one (or both) are soot black, the bike's running very rich.
Check you're getting a good strong spark off both plugs.
Undo your carb drain bolts and check nothing but nice clean fuel comes out the bottom, any watery rusty, floaty bits are a sure sign of water and gunk in the tank
Best of luck
Old 16-02-06, 06:09 PM   #3
Biker Biggles
Biker Biggles's Avatar
Choke cable?Check it's not sticking and the carb plungers are free.
Old 16-02-06, 06:23 PM   #4
JakeRS
dont think it is, cos it idles fine...
Old 16-02-06, 09:36 PM   #5
Benzito
Hey, I've started having the same problem with my '00 as well.
I've checked the fuel system and pulled the carbs to clean, then I went to check the electrical and found the ignitor coils to be coming up way short of the spec'd voltage.
Chased it back through the coupler and down to the starter. Found the starter to be good, but came back with a weird resistance reading from the white wire. Not sure how it all fits together, but I'm going to do the carbs tonight and see what that does.
I'll let you know how it turns out, but if you find anything else on yours in the meantime, let me know.
Old 16-02-06, 10:27 PM   #6
Iansv
Got similar with mine, very intermittant but really bad when low on fuel so i'd imagine its crap in the tank
Old 16-02-06, 10:46 PM   #7
JakeRS
cheers guys, will give it all a go at the weekend.
mines all filled up but its still crappy (
Old 17-02-06, 07:35 AM   #8
And check for water in the carbs.
Old 17-02-06, 11:02 AM   #9
JakeRS
Hmm, was riding to work today, it cut out twice at lights at the beginning and mid/end of my journey, but then stayed alive when I got to work
Well, tis the weekend tomorrow, the ER5 will be fixed, and I'll be riding that to work.
Old 17-02-06, 11:37 AM   #10
JakeRS
Also my Dad suggests it may be the electrics, as it is cutting out at random times.
Maybe a liberal spray of WD40 will help...
Hey guys! Ruthja2801 Idle Banter 206 16-02-09 10:36 PM
Flooding the engine gerbrox Bikes - Talk & Issues 4 04-09-08 12:15 PM
Hi Guys Scarecrow SV Talk, Tuning & Tweaking 14 08-07-08 11:40 AM
flooding kwak zzr Idle Banter 22 27-06-07 11:44 PM
Just for you guys Anonymous South & West Surfers 6 07-04-06 10:51 AM
