Old 18-02-06, 11:47 AM   #1
kjames
Default outlook question.
a quick question to all those techie types out there.
I use outlook for my diary, email etc, and run it on my laptop. now when i connect wirelessly at home, i can send and recieve emails and everythings dandy.
when i connect at work or anywhere else for that matter i can recieve emails but not send them..
cant remember the exact message, but it doesnt find my SMTP server. i've checked the settings in the email accounts setting box and all appears fine.
internet all works, and i'm recieving emails so i'm defo connected. My provider at home is wanadoo and anywhere else it is whatever provider is available.
thanks in advance
karl
Old 18-02-06, 11:55 AM   #2
TSM
The Sick Man
TSM's Avatar
Its most likley that your work blocks the outgoing SMTP ports to the net, well i do at my office. Its not needed when the company has an internal network & limits virus activity if it gets on your network ( for viruses that have their own SMTP engine & bypass outlook).
I think its that because you say it cannot find the SMTP server, if it gave a error message along the lines of relaying, unknown host etc... then i would say that it was because you are trying to connect to the SMTP host of another ISP which normaly is not allowed.
Talk to your IT dept and see if they have another SMTP server you can setup. I would create two accounts in Outlook, 1 for home & office. Set only 1 to receive your email and both to send, with a prefrence to send via the wanadoo servers. The second would be set to manual sending. That way when you create an email you select in the message what account you want to send the email through.
It can be confusing, but i have about 10 accouns on my computer for various things.
Old 18-02-06, 11:58 AM   #3
kjames
thanks for the advice, i'll have a word with IT guy on monday... not holding out much hope as he's a tad 'special needs'
I think he's the love child of one of the partners and the accounts manager... thats the only reason i can think of why he would still be employed
k
Old 18-02-06, 12:08 PM   #4
TSM
The Sick Man
TSM's Avatar
you can easly check if the SMTP port 25 is blocked.
Code:
Start > RUN > telnet mail.bbc.co.uk 25
You should see something like:
Code:
220 gateg.kw.bbc.co.uk ESMTP Sendmail 8.11.2/8.11.2; Sat, 18 Feb 2006 12:03:34 GMT
If you see it then the port is open, if not then its closed.
If its open you could try finding out the ISP that you are with.
Goto www.dnstools.com, it should show your company ip address, click on it and it will give you a Whois output on who owns the IP address and what ISP its connected to.
With that info you may be able to find out what you ISPs SMTP server is.
Usaly they are things like:
Code:
mail.ISP.com
smtp.ISP.com
mailhost.ISP.com
Old 18-02-06, 12:30 PM   #5
kjames
thanks much appreciated..
i'll give it a go on monday... looks very advanced stuff for me. but hey tinkering is fun
k
Old 18-02-06, 12:44 PM   #6
timwilky
timwilky's Avatar
One of the sites I visit blocks SMTP. So I got round it by enabling SMTP on an additional port of 10025 on my mail server, that way when I use my outlook client I can send personal mail from the office.
Strange way to run a firewall, they explicitly block certain services, rather than explicitly enable certain services. But as it is a branch office they probably take the view that they don't want to interfeer with site to site traffic, but simply don't want personal SMTP on their LAN.
Bit daft, I could understand blocking POP3/IMAP etc as you would probably not want to enable receipt of mail that has not gone through your corporate servers for anti virus etc. But to restrict outgoing makes little sense.
Not Grumpy, opinionated.
Old 18-02-06, 02:53 PM   #7
TSM
The Sick Man
TSM's Avatar
If you think about it from a diffrent point, what ever gets sent from the company will show their IP. Virus sending out rubish could blacklist the company IP causing huge problems and also possably bring a legal issue for what has been sent from the company. Its more about liability IMO.
I block all services and only allow HTTP80/HTTPS443 going out of the company workstations, DNS/POP/SMTP is all handled by the company servers and you cant send email through the servers unless the from address is a valid registed company email.
Old 19-02-06, 10:23 PM   #8
The Mass
You may also want to check your outlook profiles.
If the profiles have been setup for outbound / inbound SMTP servers going through your ISP , when you get to work, the profile will not work.
I think you'll probably find that your compnay isn't blocking SMTP or POP3 for that matter, as they pretty much depend on it for all inbound mail traffic.
The other factor may also be your anti-virus software, if it's McAfee's EPO stuff, then SMTP can be blocked by the administrator. But you would probably find that your outbound / inbound controls wouldn't work at home either.
I would have a quick look at your outlook profiles first
Mass
Old 19-02-06, 10:58 PM   #9
wheelnut
It was that bit that intrigued me the most :P
Old 20-02-06, 09:37 AM   #10
kjames
thanks for the advice... i did the check to see if the port was open as described by TSM... and it is.
then did the dnstools thing... but it didnt list anything about smtp servers. its an AOL account we have ??
anyway, now i'm stuck again. I havent managed to follow the bit about outlook profiles... which menu is this? is this the same as email account settings?
karl
Mass
MS Outlook techie question Tris Idle Banter 6 01-10-08 10:59 AM
Little bit of help with Outlook pls Stu Idle Banter 9 26-09-08 10:58 PM
Outlook Help Luckypants Idle Banter 10 27-05-08 06:49 PM
Outlook help Ratty Idle Banter 2 08-02-08 09:57 PM
