Old 21-02-06, 02:30 PM   #1
branny
Default axle right at back of tensioner ??
fitted my chain from the box.
SSS chain....... supposedly for SV650.
i had to tighten the tensioners right up against the back edge to make the chain the correct tension....... im worried about it stretching and then having nowhere to go....
hmm.
do we think i was given the wrong chain?
surely removing a link will be far too much tighter?
Old 21-02-06, 02:32 PM   #2
andy
Take a link out, did you actually count the links to make sure it was right?
Old 21-02-06, 02:32 PM   #3
branny
oops.... no!
i asked at the shop though.... i assumed a certain bike should have a certain chain...
Old 21-02-06, 02:35 PM   #4
Should do, aye. Is it 110 links in an SV chain? If you've got a smalelr rear sprocket than standard that'd also have the same effect...
Old 21-02-06, 02:37 PM   #5
branny
well... i'll count up the links then......
ive got 44/15 gearing.....
standard i think.
Old 21-02-06, 02:49 PM   #6
timwilky
timwilky's Avatar
I bet you got a naked ie 110 chain and not a 108 link one for an S
Not Grumpy, opinionated.
Old 21-02-06, 03:29 PM   #7
Stig
As Tim has said. If you have a fared bike, there is a possibility that they have given you the naked chain.
The fared bike has 44 tooth rear sprocket and 108 link chain. The naked has a 45 tooth rear sprocket and a 110 link chain.
If this proves to be the case and you have the wrong chain, don't bother to go and changed the chain, change the rear sprocket instead. You wont be disappointed.
Old 21-02-06, 04:43 PM   #8
Biker Biggles
Biker Biggles's Avatar
Was it supplied with sprockets?If so it should fit the bike as you will either have the naked or the S set up.not an incorrect mixture of the two.
Old 21-02-06, 05:46 PM   #9
Toypop
So when my chain wears out it would be recommended to replace it with the naked chain and sprocket set?
Old 21-02-06, 05:48 PM   #10
Carsick
if you want to be able to accelerate a little harder but lose a little top end, then yeah.
I went for a 15/46 setup with a 110 link chain (I think) anymore on the back would need an even bigger chain.
Rear wheel axle nut sweepdoggydog Stuff Wanted 0 25-04-09 07:47 PM
Rear axle nut alternatives? arcdef SV Talk, Tuning & Tweaking 11 08-04-09 03:03 PM
Front axle grease rob13 SV Talk, Tuning & Tweaking 1 03-09-07 06:43 AM
Hollow Axle for 02 SV650 kenedy74 SV Talk, Tuning & Tweaking 9 15-06-07 04:27 PM
Front axle bolt TSM SV Talk, Tuning & Tweaking 6 04-08-05 06:51 PM
