Through the grapevine a few months ago I heard you can replace a rear SK2 with a SK3 as long as you get different bearings.
The rear has been going fine for the last 6 months but its only now that I realise that the inner diameter of the bearing for the cush drive is around 2-3 mm larger than the axel diameter. Can someone please tell me if this is normal ? Has anyone else had any issues in transferring an SK2 rear wheel onto an SK3? Also would someone know where I can get a diagram of the rear axel assembly for both SK2 and SK3. Even a text diagram of each of the components would be great :> Thanks lads ! |
#2 | |
I have the following from left to right
Axel head chain adjuster guide swingarm rubber membrane cush drive bearing cush drive assy. wheel bearing metal tube spacer (~5cm) wheel wheel bearing rubber membrane metal spacer(~2cm with two diameters of ~1cm) swingarm chain adjuster guide axel nut Is this correct or am I missing something ? |
#4 | |
Damn im missing a (11) retainer from the chassis pdf !
LMAO No wonder the rear end felt like turd! This is like the third bearing ive went through in a year and a half |
"I realise that the inner diameter of the bearing for the cush drive is around 2-3 mm larger than the axel diameter"
That's a little worrying! Is that the wheel bearing or the sprocket carrier bearing? So you appear to have a wrong sized bearing somewhere as well as missing the spacer that sits between the sprocket carrier and the swing arm plus the spacer that fits inside the sprocket carrier between it and the wheel. |
SV650K2 (Silver) breaking for spares | mjf65 | For Sale - SV's and SV related items | 57 | 04-09-08 07:56 PM |
front wheel problems | kenada | SV Talk, Tuning & Tweaking | 17 | 02-09-08 04:28 AM |
Cleaning all around the rear wheel / swingarm / rear brake caliper | Camel | SV Talk, Tuning & Tweaking | 12 | 28-04-08 02:00 PM |
Fitting taller bars to SV650k2 | phlipperz | SV Talk, Tuning & Tweaking | 4 | 22-08-06 11:22 PM |
Brand New Blue SV650K3 Hugger | Mike1234 | For Sale - SV's and SV related items | 1 | 16-12-05 10:24 AM |
