View Poll Results: Is stainless steel stronger then normal steel (axle) | |||
Yes |
3 | 15.79% |
No |
13 | 68.42% |
Don't know but sounds like a good idea |
3 | 15.79% |
Voters: 19. You may not vote on this poll |
Thinking of sourcing a stainless steel bolt and nut for the real axle
Don't use stainless for critical stressed items like wheel spindles.
#3 | |
Definately weaker, that's why there aren't stainless bits readily available for such areas, such as the:
The tensile and sheer strength of high carbon stainless steel is higher than that of mild steel. The thing is that stainless is more brittle (in most cases) than mild steel. So the vibrations and jarring of the wheel on the axle could cause micro-fissures in the steel making it weaker.
So like everyone else said, I wouldn't use it for your axle. |
Yoyodyne do titanium spindles for the SV rear and GSXR front
stainless steel is definitely not strong enough as it cannot be heat treated to increase tensile strength, only work hardened which does not make it strong enough. if you take a file to your axles you will find that it hardly makes an impression which shows how tough it is. i see in the demon tweeks catalogue that they sell st/st disc bolts which worries me for the same reason. you could buy a titanium bar from probolt and have a local engineering shop make one from your original. i have my spindles replated every year to keep them looking good it costs £20.00 for the pair
Having read the other responses I've voted 'no'.
#8 | |
![]() ![]() it's not like its the most visible part of the bike ![]() regular cleaning and greasing is far easier ![]() and as others have stated its not a good idea really ![]() |
#9 | |
#10 | |
Stainless steel rod | dirtydog | Bikes - Talk & Issues | 15 | 15-02-09 12:52 AM |
Scorpion stainless steel can | plowsie | For Sale - SV's and SV related items | 11 | 04-12-07 04:54 AM |
Stainless Steel Down Pipes | New Leaf | Bikes - Talk & Issues | 1 | 21-10-07 11:00 AM |
To stainless steel or not to stainless steel...... | svrash | SV Talk, Tuning & Tweaking | 39 | 21-04-06 09:04 AM |
Polishing Stainless steel ? | gc350 | SV Talk, Tuning & Tweaking | 8 | 09-01-06 09:19 PM |
