I've just cleaned up my pistons as they were binding onto the discs, but I ended up reusing the seals and slightly
I got prices for the seals when before i pulled all my brake system apart and to be honest for a few washers i was shocked at the price
Front Caliper Seal kits £12.64 inc vat per caliper Rear Caliper Sael Kits £21.19 inc vat I got away with using the front seals again as only the dust seals that showed any real signs of wear and tear but needed new rear set ![]() Not sure on the piston price but for a wild guess going by dealer prices I would imagine £20 a piston but like I say im purely guessing on that |
how much do new calipers cost, I have discovered it's a waste of time & money to rebuilt them, New SV calipers are relatively cheap (in the US)
Decent secondhand calipers can be got for £30-£35 from breakers. Looking at around £120 each for aftermarket brand new.
Why are the rear seals more expensive? There's the same number of them as the front ![]() |
Rear Pistons are larger than the front, plus there is a seal between the 2 halves of the caliper whic is probably accounting for some of the extra.
Never felt the need to replace a caliper as they really don't tend to wear, if you buy 2nd hand ones you run the risk of picking up a set in the same condition or worse than yours, better to spend an hour or so to do a propper strip, clean, grease & rebuild IMHO. Pattern parts are your friends, you can get non Susuki seals & pistons for less than the OE kit.
Brake Overhaul - picture heavy | Al_Sweetman | SV Talk, Tuning & Tweaking | 37 | 27-02-09 10:44 AM |
Brake Overhaul | Crash_Artist | SV Talk, Tuning & Tweaking | 3 | 18-02-09 07:44 PM |
Bike Overhaul | sv_rory | SV Talk, Tuning & Tweaking | 32 | 13-02-09 04:34 PM |
Caliper overhaul. | arcdef | SV Talk, Tuning & Tweaking | 114 | 31-01-09 04:57 PM |
Front brake overhaul - how much? | DarrenChay | SV Talk, Tuning & Tweaking | 7 | 03-01-09 09:12 PM |
