Old 15-03-06, 12:45 PM   #1
Dreadhead
Default 2001 sv650 engine problems, help needed
iv got a 2001 suzuki sv650s and it seems every time i wash it the engine starts to play up i think theres water some where in the electrics which is making my front cylinder not fire i thought it might be water sitting in the cylinder top where the spark plug seats i try'ed to dry it out the best i could but it made no difference at all
after washing the bike i run it for about 20minuits while i do the chain then i ran it for 30 mins on my way home after work and it seemed fine but when i came to it the next morning it would'nt run properly at all
has anyone got any ideas what it could be or do you think i could still has some water residue on the spark plug cap
thanks,
kenny
Old 15-03-06, 01:04 PM   #2
instigator
When you tried drying it out, did you take the HT lead off and remove any moisture of that? No little drain hole that's blocked?
Old 15-03-06, 01:14 PM   #3
Dreadhead
i took the cap all the way off then put some tissue papper in to try and dry it out if i use some WD40 do u think that would do the trick at all
as for drain plugs i didnt know there was any there where abouts are they so i can check there not blocked?
Old 15-03-06, 01:21 PM   #4
I don't think it'll be the usual front plug thing... Unless you're seriously blasting the front of the engine with a powerwasher or similiar, it just shouldn't get that wet (unless the seal's missing). I reckon you mighht well have a problem further back, at the coil end.If you hose or pressure wash the side of the bike and there's a bad connection in there, it wouldn't take much water to mayeb cause a problem.
Old 15-03-06, 01:24 PM   #5
Dreadhead
i did use a preassure wash but on the lowist setting so not much pressure was there. how would u suject i sort it if it is the coil
Old 15-03-06, 01:42 PM   #6
Not really sure to be honest. The front coil is down the left hand side of the engine, bolted to the frame- The wiring routes round the front and left of the frame, I think, and then down. So, I'd be checking the wiring for holes, and the coil connections for, well connection. Damage, fitment, corrosion. Maybe get in there with some silicon grease to give it better insulation.
But then, before i did that I'd speak to some of the various people on the forum that are better with electrical stuff... I know the basics, and I can fix a problem when I can find it, but that's really the limit. Electrics are always a sod, especialyl since they tend to be intermittant and hard to trace.
sv650 2001 parts needed LOOK! chompy Stuff Wanted 3 21-03-09 08:06 PM
2001 SV Engine and other bits Moustachio For Sale - SV's and SV related items 6 08-08-08 08:30 PM
wanted - engine to fit 2001 curvy adam_castell Stuff Wanted 1 22-09-06 10:58 AM
Help! 2001 SV650S starting problems kellie000 SV Talk, Tuning & Tweaking 8 04-07-06 03:17 PM
parts needed for 2001 hduc Stuff Wanted 4 27-11-05 07:59 PM
